Trying to implement a SOS for the first time
Kralidis,Tom [Burlington] Tom.Kralidis at EC.GC.CA
Wed Sep 27 11:31:13 EDT 2006
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Hinrich Paulsen
> Sent: Wednesday, September 27, 2006 9:25 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] Trying to implement a SOS for
> the first time
> Dear List,
> posting to this list for the first time and am promptly
> rejected by the system. Hopefully it is not an omen. :-)
> Well, here is my question again.
> Dear List,
> I am in the process of setting up a Sensor Observation
> Service (SOS) for the first time using a Kubuntu-Linux
> machine and the following Mapserver:
> MapServer version 4.10.0-beta3 OUTPUT=GIF OUTPUT=PNG
> OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ
> SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=SOS_SERVER INPUT=EPPL7
> INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> My data is sitting in a Postgis table which I can easily
> access via WMS.
> I have consulted the documentation at:
> http://mapserver.gis.umn.edu/docs/howto/sos_server/
> and when trying out the examples given there the
> GetCapabilities and  DescribeSensor Requests work fine so far
> but the GetObservation Request does not.
> My idea of how the GetObservation Request should work is that
> data in a specific column in my Postgis table is returned
> when I define it in my SOS server mapfile. Here is a snippet
> of the mapfile:
> <SNIP>
> LAYER
>   NAME test_sos_layer
>   DUMP TRUE
>   METADATA
>     "sos_procedure"  "SW01UTL001"
>                            ## REQUIRED
>     "sos_offering_id" "r_wert"
>                                     ## REQUIRED
>     "sos_observedproperty_id" "r_wert"
>                             ## REQUIRED
>     "sos_describesensor_url"
> "http://localhost/temp/SW01UTL001.xml"   ## REQUIRED
>   END
>   TYPE POINT
>   STATUS ON
>   CONNECTIONTYPE postgis
>   CONNECTION "user=myuser dbname=mydb host=localhost port=5432"
>   DATA "the_geom FROM (SELECT * FROM mytable) AS foo USING
> UNIQUE gid USING SRID=31467"
>    PROJECTION
>      	'init=epsg:31467'
>    END
>  CLASS
>     NAME 'r_wert'
>        STYLE
>         SYMBOL 'circle'
>         SIZE 5
>         COLOR 255 100 50
>         OUTLINECOLOR 0 0 0
>       END
>  END
> END
> </SNIP>
> When I send this there is no error but all I get back is this:
> <om:ObservationCollection gml:id="r_wert"
> xsi:schemaLocation="http://www.opengeospatial.net/om
> http://schemas.opengis.net/om.xsd"/>
> Where am I going wrong? Any help on pointing me in the right
> direction is highly appreciated!
Weird.  What's your GetObservation request URL?
Also, you can test to see if this is even working via WMS or WFS as
sanity check against the data connection, or even a mapserv CGI request.
Let us know what your results are.
..Tom
