Fwd: Problems with importing WFS in UDig
Rahkonen Jukka Jukka.Rahkonen at MMMTIKE.FI
Thu Sep 28 11:41:18 EDT 2006
I am almost sure I faced this same problem with uDig and a bit older Mapserver version. In addition another WFS client reported the same error when used in http POST mode, while http GET was OK. But even if my own WFS services failed (built on MS4W) the demo WFS site of the DM Solutions worked in both GET and POST modes and I suppose it is Mapserver WFS. I could not solve the problem and changed to Geoserver WFS.
I believe this problem is easy to repeat with MS4W-WFS and for example CadCorp Sis map browser.
Regards,
-Jukka Rahkonen-
-----Original Message-----
From: UMN MapServer Users List on behalf of Eijnden, Bart van den (AGI)
Sent: Thu 28.9.2006 16:11
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Fwd: Problems with importing WFS in UDig
Can you post the WFS GetCapabilities response?
Apparently uDIG encounters a <BR> tag somewhere (without </BR>), which is likely an HTML tag.
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Karin Kampitsch
Verzonden: donderdag 28 september 2006 14:54
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: [UMN_MAPSERVER-USERS] Fwd: Problems with importing WFS in
UDig
Dear Mailing List,
I have problems with importing Features from a WFS in the free GIS Software "UDig" (MapServer 4.8.4).
After entering the WFS Request
"http://localhost/cgi-bin/mapserv.exe?map=features/wk_wfs.map&VERSION=1.0.0&SERVICE=WFS&REQUEST=GetCapabilities"
UDig reports the following error message:
 "The element type "br" must be terminated by the matching end-tag "</br>" "
What does this error message mean?
The Layer in the WFS Mapfile looks like this:
LAYER
  	NAME "Schloss"
  	STATUS ON
	DATA "schlk"
  	TYPE POINT
  	PROJECTION
    		"init=epsg:23033"
  	END
  	DUMP TRUE
  	CLASS
   	 SYMBOL "bild_schloss"
         TEMPLATE "index_wfs.html"
        END
	METADATA
    	     "wfs_title" "Schloss"
    	     "gml_include_items" "all"
	     "wfs_extent" "454165.1980 309893.7130 507688.8757 352760.1515"
  	END
END
END
Is there maybe an error in the mapfile?
But the GML Code appears, after entering the WFS Request in the Internet Explorer.
Could you please help me?
Thanks,
karin
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
