Fw: raster layer
Rahkonen Jukka Jukka.Rahkonen at MMMTIKE.FI
Thu Sep 28 11:50:10 EDT 2006
Perhaps your image is missing georeferencing data? Check it with gdalinfo. If this is the case, then construct ESRI type world file (.wld) for your image. If your image is in another projection than your vectors you must add the correct projection to your raster layer definition as well.
Regards,
-Jukka Rahkonen-
-----Original Message-----
From: UMN MapServer Users List on behalf of Alessandro MAZZELLA
Sent: Thu 28.9.2006 18:38
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Fw: raster layer
Hi list,
    i've got a very very very little problem ... i'm developing a very simple mapserver application for displaying a shape layer on a raster background image (jpeg).
    mapserver returns no error, but the raster image is not showed on the result !!!
    some ideas ??
     **** this is the mapfile:
MAP
 NAME a003
 IMAGETYPE GIF
 EXTENT 1414770 4298268 1590137 4578665
 SIZE 800 800
 SHAPEPATH "/home/mapserver/data/shp/"
 IMAGECOLOR 255 255 255
 SYMBOLSET "/home/mapserver/data/symbols/symbols35.sym"
 FONTSET "/home/mapserver/data/fonts/fonts.list"
 WEB
  IMAGEPATH "/home/mapserver/htdocs/tmp/"
  IMAGEURL "tmp/"
 END
###SHP Layer
 LAYER
  NAME "shape"
  TYPE POLYGON
  STATUS ON
  DATA "shape"
  CLASS
   STYLE
    COLOR 1 1 1
    OUTLINECOLOR 32 123 176
   END
  END
 END
###RASTER
 LAYER
   NAME "raster"
   TYPE RASTER
   STATUS ON
   DATA "/home/mapserver/data/shp/raster.jpeg"
   CLASS
     NAME "raster"
   END
 END
END
Tnks all
Ciao,
Alessandro MAZZELLA
      ---->> Cagliari ( Lat. -N- 39°13'23"24, Lon. -E- 09°6'25"46 )
