bugs : msDBFGetItemIndex(): DBASE file error. Item not found
Andreas Albarello andreas.albarello at TERRITORIUMONLINE.COM
Thu Sep 28 12:49:51 EDT 2006
Fabio D'Ovidio wrote:
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=674
> Is this bug solved ? I am using mapserver 4.8.3 on Windows
> Please I am trying to do this but I am not able to query the JOIN table
> or display my classification on "LIVELLO" item . Please HELP !  :
Fabio,
no, this "bug" (I'd say this is a missing feature rather than a bug) has
not been solved and I don't expect it to be solved anytime soon.
To clear things up a bit (the documentation is not very detailed about
this), this is what holds true as far as I know: you can't query a map
or a layer on one of its joined fields (I'm referring to joins using the
JOIN object only), you can't set the labelitem or the classitem to one
of the joined fields etc. Basically you can't do *anything* with them at
all except for displaying their contents on a HTML template.
It should however be possible to do what you want using OGR. Please
refer to this document for a howto:
http://mapserver.gis.umn.edu/docs/howto/ogr_howto
Best regards,
Andreas Albarello
Analysis & SW Development
Territorium Online srl/GmbH
Via Buozzi Str. 12
I 39100 Bolzano/Bozen
Phone:  +39 0471 068611
Fax:    +39 0471 068619
email: andreas.albarello at territoriumonline.com
web:   http://www.territoriumonline.com
