What is ids in imagemap example?
Randy James
rjames57 at YAHOO.COM
Thu Sep 28 17:03:06 EDT 2006
i believe id is the name of a variable, the two % show the start and the end of the variable.
check out
http://umn.mapserver.ch/MapServer/en/syntax.htm
randy
"Trimble, Beheen" <btrimble at SFWMD.GOV> wrote:
st1\:*{behavior:url(#default#ieooui) } Hey People,
I am still trying to make the mouseover works in my application!
Do you know what is %ids% in below map? Where this is defined?
Thanks
Beheen
MAP
NAME "TEST"
SIZE 380 450
EXTENT 180000 4816000 773000 5474000
UNITS METERS
IMAGECOLOR 252 252 252
SHAPEPATH "/r01/data/drs"
FONTSET "/usr/local/mapserver/fonts/fonts.list"
WEB
HEADER "templates/imagemap_header_example.html"
FOOTER "templates/imagemap_footer_example.html"
IMAGEPATH "/usr/local/www/docs_maps/tmp/"
IMAGEURL "/tmp/"
END
QUERYMAP
STATUS ON
STYLE NORMAL
END
LAYER
NAME county
STATUS OFF
DATA "data/bdry_counpy2_gen500"
TYPE POLYGON
# LABELITEM "CTY_ABBR"
CLASS
EXPRESSION ('[COUN]' in '%ids%')
STYLE
COLOR "#BD9E5D" # "#A27528"
OUTLINECOLOR 50 50 50
END
END
CLASS
COLOR 255 255 255
END
TEMPLATE "templates/county_example.html"
END # counties
END
Do you Yahoo!?
Everyone is raving about the all-new Yahoo! Mail.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060928/de4a6b68/attachment.html
