php/mapscript and client-side imagemaps
Matt Pettis
matt.pettis at THOMSON.COM
Tue Apr 3 23:14:18 EDT 2007
I'm trying to get generate a client side imagemap (the <map>...</map>) coordinates and inserting the text using just php/mapscript (avoiding using the templating methods found at http://mapserver.gis.umn.edu/docs/howto/imagemaps because I want as pure a php solution as i can get). I found the wiki entry for this (http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?ImageMap), and followed its instructions. In particular, the following lines did not generate what I thought:
$imgmap = ms_newMapObj( "C:\\ms4w\\Apache\\htdocs\\postgis\\imgmap.map" );
$imgmapimg = $imgmap->draw();
$imgmapurl = $imgmapimg->saveWebImage(MS_IMAGEMAP,1,1,0);
I couldn't find documentation on saveWebImage, but I thought it would generate the text i would need to include in a <map> section for my webpage. Instead, what was generated was a .png file. Should this be usable as an image map, or did I get this in error (the page rendered just fine).
Can someone help me fix this? Ultimately, I am looking to emulate the great ease from the templating solution, but just in php. I am rendering the counties of MN as polygons and would like to request a different URL based on which county is clicked. Anyone have a solution/hints along this direction?
Thanks,
Matt
