[PHPMapScript] Pb to set the angle property of a LabelObj
Daniel Morissette dmorissette at MAPGEARS.COM
Wed Apr 4 13:15:16 EDT 2007
Loïc MAZE wrote:
> Hi all,
> I have some troubles with the current version of PHPMapScript. My
> problem is very simple : I would like to set the "ANGLE" property of a
> LabelObj with the value "FOLLOW". I have searched a way to do a such
> thing but it was unsuccessful. The only thing I have found is how to set
> this property with the value "AUTO" (with the following code :
> $oLabel->set("autoangle", MS_AUTO); ).
Um, it seems that the MS_FOLLOW constant is missing in PHP MapScript.
I have filed a bug about this and added the constant in both the dev
version (future 5.0) and in the 4.10 branch (will be in 4.10.2):
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=2058
As a workaround until you can upgrade, you should be able to use the
following:
$oLabel->set("autoangle", MS_AUTO+2);
Daniel
Daniel Morissette
http://www.mapgears.com/
