varibale angle in annotation layer
Fawcett, David
David.Fawcett at STATE.MN.US
Mon Apr 9 11:59:41 EDT 2007
Giuseppe,
To create rotated labels, you need to use TrueType fonts.
It looks like you are already trying to use TrueType, just change the
value of TYPE (in your LABEL block) to truetype.
At the LAYER level, you will also need to add LABELANGLEITEM. See the
mapfile reference at:
http://mapserver.gis.umn.edu/docs/reference/mapfile/layer
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Giuseppe De Rossi
Sent: Monday, April 09, 2007 10:22 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] varibale angle in annotation layer
I wrote the following definition of a layer:
LAYER
NAME 'MyAnnotationShape'
TYPE ANNOTATION
DATA 'MyAnnotationShape'
STATUS DEFAULT
LABELITEM "STRING"
CLASSITEM "STRING"
CLASS
NAME 'All'
EXPRESSION /./
STYLE
COLOR -1 -1 -1
END
LABEL
COLOR 255 255 51
ANTIALIAS TRUE
SHADOWCOLOR 0 0 0
SHADOWSIZE 1 1
TYPE BITMAP
FONT arial
SIZE LARGE
POSITION CC
PARTIALS FALSE
BUFFER 2
END
END
END
The layer is well displayed but the labels have all the same orientation
(orizhontal), but the original orientation of those label is variable,
which is the instruction in order to have a varible orientation ? How
can I use the column ANGLE in the dbf which defines for each label its
correct orientation ?
Thanks in advance
Giu
Email.it, the professional e-mail, gratis per te: http://www.email.it/f
Sponsor:
Fai crescere i tuoi sogni. Prestiti semplici e veloci
Rate da 20 euro al mese
Clicca qui: http://adv.email.it/cgi-bin/foclick.cgi?mid=6332&d=20070409
