GetFeatureInfo XML-Template
Bart van den Eijnden (OSGIS) bartvde at OSGIS.NL
Tue Apr 10 05:01:35 EDT 2007
You can just use gml_include_items "all" and have Mapserver output GML. You
don't need any XML template for this.
http://mapserver.gis.umn.edu/docs/howto/wms_server
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Dmitri Mizerkin <mizerkin at WIRZ-KOELN.DE>
Naar: MAPSERVER-USERS at LISTS.UMN.EDU <MAPSERVER-USERS at LISTS.UMN.EDU>
Onderwerp: [UMN_MAPSERVER-USERS] GetFeatureInfo XML-Template
Datum: 10/04/07 06:58
> Hi list!
> &nbsp;
> I would like to make a GetFeatureInfo-Request and get
> an xml-file with the results, where all the fields would be listed
(something
> similar to this response in this example:
http://interops.esri.com/help/wms_gfi.htm).
> As far as I know, in this case there should be an xml-template
> provided. The problem is that I don&#8217;t know all the field-names of
the
> query-layer. Is it possible to set up the template so, that it lists all
the
> fields, not having to type the fieldnames into the template manually?
> &nbsp;
> Thanks in advance!
> &nbsp;
> Regards,
> ________________________________
> Dmitri Mizerkin
> &nbsp;
