map and hyperlinks
Fawcett, David
David.Fawcett at STATE.MN.US
Fri Apr 13 09:11:00 EDT 2007
If you follow Rich's method, I think that you can use a variable
substitution in the URL string to make it specific to the feature
clicked.
Another method would be to make two calls to mapserv, one to get the map
image, and the second one to get an imagemap. You then stack them on
top of each other and you can have a clickable map, mouse-over text,
etc.
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Richard Greenwood
Sent: Thursday, April 12, 2007 10:18 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] map and hyperlinks
On 4/12/07, Giuseppe De Rossi <giuseppe.derossi at email.it> wrote:
> Hi,
> is there the possibility to create a layer which contains a number of
> clickable icons so there is a redirection to another web page ?
> thanks in advance
> Giu
Yes. In the LAYER > CLASS > TEMPLATE you can set the template to a url.
Richard Greenwood
richard.greenwood at gmail.com
www.greenwoodmap.com
