Virtual Spatial Data & QUERY control ? Wrong result
David Lowther dlowther at COORDINATESOLUTIONS.COM
Fri Apr 13 09:28:32 EDT 2007
Jan,
I had this same experience - though I didn't track it down to returning the
first record, just that it was always the same one.
For help locating the issue, I was using mapscript_csharp v 4.9.
David Lowther
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Jan De Belder
Sent: Friday, April 13, 2007 3:41 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Virtual Spatial Data & QUERY control ? Wrong
result
Hi all,
Is there a way to use query or nquery on a virtual spatial data layer in
MAPSERVER ? I cannot get this to work.
Description of my setup:
*windows xp pro, IIS & mapserver (latest ms4w).
*I have a working virtual spatial data layer in my mapfile, with appropriate
labelling
*I have a lightweigth AJAX client which can identify (NQUERY) all layers and
gives correct results
Problem
* when using the identify (NQUERY) on a virtual spatial data point, the
query always returns the FIRST record in the ODBC source, not the one that
is clicked on by the pointclick (Mind you, when I use exactly the same data
in a shapefile, the identify works, and labelling on the virtual spatial
data points also works).
http://mapserver.gis.umn.edu/docs/howto/ogr_howto/#queries-through-ogr-forma
t
states that OGR queries should works the same as shapefiles. Does this not
apply to Virtual Spatial Data layers ?
Any thoughts ?
Thanks
Jan De Belder
Katholieke Universiteit Leuven
