R: [UMN_MAPSERVER-USERS] disable dbox
Piero Cavalieri Piero.Cavalieri at HEIDI.IT
Fri Apr 13 10:22:41 EDT 2007
No, I didn't. I'm using the 'old' dbox (uses X library). Maybe there
wasn't at that time. If so, there is example code somewere ? I remember
there was in jbox, but I'm using js.
Thanks
 Piero
On 4/13/07, Piero Cavalieri <Piero.Cavalieri at heidi.it> wrote:
> Hi all,
> I would like to implemet measure tool via dhtml. Currently I'm using
dbox,
> but I would like to temporary disable
> It while digitizing and then restore dbox after the measure tool have
done
> the job.  I found dBox_reset()  which require to implement a
> reset_handler(...) function. I'm a bit confused on how to disable
dbox, so
> could someone explain me this ?
> Thanks
>  Piero
Do you know that there is a measure handler already in dBox?
Richard Greenwood
richard.greenwood at gmail.com
www.greenwoodmap.com
