R: [UMN_MAPSERVER-USERS] R: [UMN_MAPSERVER-USERS] disable dbox
Piero Cavalieri
Piero.Cavalieri at HEIDI.IT
Fri Apr 13 11:16:49 EDT 2007
I found it in dbox that comes with ms4w. I'll have a bit of work to integrate it, cause I done the web app in my own manner (old dbox/ajax/.net), however it's a starting point.
Thanks
Piero
-----Messaggio originale-----
Da: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] Per conto di Piero Cavalieri
Inviato: venerdì 13 aprile 2007 16.23
A: MAPSERVER-USERS at LISTS.UMN.EDU
Oggetto: [UMN_MAPSERVER-USERS] R: [UMN_MAPSERVER-USERS] disable dbox
No, I didn't. I'm using the 'old' dbox (uses X library). Maybe there
wasn't at that time. If so, there is example code somewere ? I remember
there was in jbox, but I'm using js.
Thanks
Piero
On 4/13/07, Piero Cavalieri <Piero.Cavalieri at heidi.it> wrote:
> Hi all,
> I would like to implemet measure tool via dhtml. Currently I'm using
dbox,
> but I would like to temporary disable
> It while digitizing and then restore dbox after the measure tool have
done
> the job. I found dBox_reset() which require to implement a
> reset_handler(...) function. I'm a bit confused on how to disable
dbox, so
> could someone explain me this ?
> Thanks
> Piero
Do you know that there is a measure handler already in dBox?
Richard Greenwood
richard.greenwood at gmail.com
www.greenwoodmap.com
