MS 4.10.1 php_mapscript build problem on FreeBSD 6.2
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Tue Apr 17 21:26:39 EDT 2007
-lfcgi is the fastcgi library. You can see if you have it loaded with
something like:
locate libfcgi
probably should be at /usr/local/lib/libfcgi*
if it is there, or somewhere on your system, check to make sure its path
is in /etc/ld.so.conf and run as root ldconfig and try again.
-Steve W
Ben Madin wrote:
> G'day all,
> I have successfully built MapServer 4.10 on FreeBSD 6.2 (my first
> attempt at UNIX building, so very excited although it didn't like the
> flash support so I dropped it)
> I realised however that I hadn't built the php-mapscript module, which
> is my main interface for development, so back I went, and added it to my
> config file (using Howard Butler's suggestion) to be :
> ./configure     --with-freetype=/usr/local/bin \
>                 --with-png=/usr/local/lib \
>                 --with-jpeg=/usr/local \
>                 --with-libiconv=/usr/local \
>                 --with-geos=/usr/local/bin/geos-config \
>                 --with-ogr=/usr/local/bin/gdal-config \
>                 --with-gdal=/usr/local/bin/gdal-config \
>                 --with-httpd=/usr/local/sbin/httpd \
>                 --with-wfsclient \
>                 --with-wmsclient \
>                 --enable-debug \
>                 --with-curl-config=/usr/local/bin/curl-config \
>                 --with-proj=/usr/local \
>                 --with-pdf=/usr/local \
>                 --with-tiff=/usr/local \
>                 --with-threads \
>                 --with-fastcgi \
>                 --with-wcs \
>                 --with-postgis=/usr/local/database/bin/pg_config \
>                 --with-php=/usr/local/include/php/ \
>                 --with-xml2-config=/usr/bin/xml2-config  # new in 4.10
> So configure worked, a quick make clean and then off we go again, until
> this... (I'm afraid I don't really understand what most of it means)
> g++ -g -O2 -fPIC -Wall  -DENABLE_STDERR_DEBUG -DNEED_NONBLOCKING_STDERR
>   -DHAVE_VSNPRINTF -DUSE_EPPL -DUSE_PROJ  -DUSE_WMS_SVR -DUSE_WMS_LYR
> -DUSE_WFS_LYR -DUSE_WCS_SVR   -DUSE_TIFF  -DUSE_GD_GIF -DUSE_GD_PNG
> -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_FTEX_XSHOW
> -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS -DUSE_PDF    -DUSE_OGR
> -DUSE_GDAL -DUSE_GEOS -DUSE_ICONV     -DUSE_POSTGIS  -DUSE_THREAD
> -DUSE_ZLIB  -I/usr/local/include -I/usr/local/include
> -I/usr/local/include -I/usr/local/include -I/usr/local/include
> -I/usr/local/include -I   -I/usr/local/include   -I/usr/local/include
> -I/usr/local/include     shp2img.o  -L. -lmap -lgd -L/usr/local/lib -lgd
> -L/usr/local/lib -ljpeg -L/usr/local/lib -Wl,--rpath -Wl,/usr/local/lib
> -lfreetype -lz -L/usr/local/lib -lpng -lz -L/usr/local/lib -lpdf
> -L/usr/local/lib64 -ltiff -L/usr/local/lib -ljpeg -L/usr/local/lib
> -Wl,--rpath -Wl,/usr/local/lib -lfreetype -lz -L/usr/local/lib -lpng -lz
> -L/usr/local/lib -lproj  -L/usr/local/lib -ljpeg  -L/usr/local/lib
> -lgdal -L/usr/local/lib -lgeos -L/usr/local -L/usr/local/lib -ljasper
> -lungif -lgeotiff -L/usr/local/lib -ltiff -L/usr/local -L/usr/local/lib
> -lpng -L/usr/local/lib -lpq -lz -L/usr -L/usr/lib -lm  -L -lpq
> -L/usr/local/lib -lcurl -rpath=/usr/lib:/usr/local/lib -lssl -lcrypto
> -lz  -L/usr/local/lib -lgeos_c  -lpthread -L/usr/local/lib -liconv
> -lfcgi  -lz  -lm -lstdc++  -o shp2img
> /usr/bin/ld: cannot find -lfcgi
> *** Error code 1
> Stop in /usr/local/mapserver-4.10.1.
> So now it doesn't work. I don't understand the significance of -lfcgi,
> or why it has become a problem now with the  inclusion of the --with-php
> flag.
> My system includes :
> Apache/2.2.4 (FreeBSD) Server built:   Apr 10 2007 22:15:11
> PHP 5.2.1 with Suhosin-Patch 0.9.6.2 (cli) (built: Apr 11 2007 09:33:50)
> (DEBUG) Zend Engine v2.2.0, Copyright (c) 1998-2007 Zend Technologies
> GD 2.0.34
> GDAL 1.3.1
> PROJ 4.5.0
> JPEG 6b
> PNG 1.2.14
> GEOS 2.2.3
> PostGIS 1.2.1
> freebsd# /usr/local/www/apache22/cgi-bin/mapserv -v
> MapServer version 4.10.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_CLIENT
> SUPPORTS=GEOS INPUT=TIFF INPUT=EPPL7 INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE DEBUG=MSDEBUG
> and my build directory is /usr/local/mapserver-4.10.1
> I guess my first question has to be will php_mapscript work with php 5?
> and then ... what is -lfcgi? (and how can I get it?)
> cheers
> Ben
> Ben Madin
> REMOTE INFORMATION
> t : +61 8 9192 5455
> f : +61 8 9192 5535
> m : 0448 887 220
> Broome   WA   6725
> ben at remoteinformation.com.au <mailto:ben at remoteinformation.com.au>
> Out here, it pays to know...
