MS 4.10.1 php_mapscript build problem on FreeBSD 6.2
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Wed Apr 18 08:59:56 EDT 2007
Ben,
Sounds like it might be a freeBSD bug in mapserver .configure script.
You requested --with-fastcgi and I would think that since it did not
find it is should have dropped the -lfcgi, but did not. You should
probably write this up as a bug.
fastcgi is on little or no benefit unless you are using oracle and need
  connection pooling. So try to configure --without-fastcgi ot just
remove the --with-fastcgi option. If one fails try the other.
-Steve W
Ben Madin wrote:
> Thank you Steve,
> I have mod_fastcgi for apache, this was installed through the FreeBSD
> ports system, and all very happily. but I didn't end up with a libfcgi
> anywhere I can find (I have mod_fastcgi.so in
> my /usr/local/libexec/apache22 directory)
> I notice in the configure I actually had this :
> configure: checking whether FastCGI support should be enabled...
> checking for FCGI_Accept in -lfcgi... no
> configure: checking HTTPD server (Apache) version...
>         using user-supplied httpd (/usr/local/sbin/httpd)
>         /usr/local/sbin/httpd version is Apache/2.2.4 (2002004).
> Compiling with fast MS_NINT
> checking compiler warnings... basic
> so maybe I never had fastcgi last time around. Do I need to get a
> different fastcgi from somewhere else, or did something maybe not go
> quite right?
> cheers
> Ben
>> *From: *Stephen Woodbridge <woodbri at SWOODBRIDGE.COM
>> <mailto:woodbri at SWOODBRIDGE.COM>>
>> *Date: *18 April 2007 9:26:39 AM
>> *Subject: **Re: MS 4.10.1 php_mapscript build problem on FreeBSD 6.2*
>> -lfcgi is the fastcgi library. You can see if you have it loaded with
>> something like:
>> locate libfcgi
>> probably should be at /usr/local/lib/libfcgi*
>> if it is there, or somewhere on your system, check to make sure its
>> path is in /etc/ld.so.conf and run as root ldconfig and try again.
>> -Steve W
> Ben Madin
> REMOTE INFORMATION
> t : +61 8 9192 5455
> f : +61 8 9192 5535
> m : 0448 887 220
> Broome   WA   6725
> ben at remoteinformation.com.au <mailto:ben at remoteinformation.com.au>
> Out here, it pays to know...
