style/color based on feature values?
Bobby Braswell rob.braswell at UNH.EDU
Wed Apr 18 13:22:25 EDT 2007
Hi-
I'd like to assign polygon colors that are rendered based on the
value of one of the feature attributes. In my case there are nearly a
hundred possible discrete classes. I could write a script to generate
a mapfile layer with a hundred classes, but I'd prefer to make a
direct link to the shapefile if possible. I hope this question makes
sense.
It seems like "styleitem" should be the thing to use here, but I have
not figured out how to make this work.
In any case if someone could post an example of either a continuous
or discrete rendering of polygon colors based on one of the data
fields in the shapefile, I'd really appreciate it.
Thanks,
Rob Braswell
