Virtual Tables
Daniel Morissette dmorissette at MAPGEARS.COM
Thu Apr 19 09:29:01 EDT 2007
For the record, we have figured part of the mystery offlist, it turns
out the VRT definition had two problems:
1- Missing required <SrcDataSource> (path to the .csv file)
2- <SrcLayer> was wrong (layer name for CSV sources is only the basename
of the .csv file)
With the above fixes "ogrinfo" could read the data, but we still do not
see the points on the map, however converting the VRT to a shapefile
does work for the same layer... that's another mystery to solve.
Daniel
Kevin Flanders wrote:
> I would like to map a virtual table, and I am told I can do it without
> declaring an ODBC…using the following mapfile layer definition:
>   LAYER
>     NAME "Fire Data"
>     GROUP "Fire Data"
>     STATUS on
>     TYPE point
>     CONNECTIONTYPE OGR
>     CONNECTION "<OGRVRTDataSource>
>                                      <OGRVRTLayer
> name='firegis'>
>                    <SrcLayer>mapsonline.csv</SrcLayer>
>                                        <GeometryField
> encoding='PointFromColumns' x='XCOORD' y='YCOORD'/>
>                                        <GeometryType>wkbPoint</GeometryType>
>                                      </OGRVRTLayer>
>                                    </OGRVRTDataSource>"
>     TEMPLATE "ttt"
>     TOLERANCE 4
>     CLASS
>       NAME "Fire
> Data"
>       SYMBOL "circle"
>       OUTLINECOLOR 80 80 80
>       COLOR 219 0 0
>       SIZE 12
>     END
>   END
> But this fails.  Do I need an ODBC….or is it true I can access a text
> file directly in this manner.  The data is being placed with all my
> other shapefiles (ie. in the same folder).
> Also, can the .csv file just as easily be a .txt file….and can the
> entries have quotations around them?
> Kevin
Daniel Morissette
http://www.mapgears.com/
