Use of different epsg code
Antonio
volpicelli at OATO.INAF.IT
Fri Apr 20 05:02:12 EDT 2007
Thanks Brent,
I start to see a bit of light.
So I tried to change units in meters but there is always something not
clear.
I have :
MAP
NAME ASTRO
STATUS ON
EXTENT -18000000 -9000000 18000000 9000000
UNITS meters
TRANSPARENT ON
SHAPEPATH "G:/GalexData/TestPoint"
CONFIG "PROJ_LIB" "E:/ms4w/proj/nad/"
PROJECTION
"init=epsg:54009" # Mollweide
END
and at the layer level If I define epsg:54009 with MAXARC=1 and
MAXINTERVAL=1500000 the graticule is just rectangular grid.
If I define epsg:4326 with MAXARC=1 and MAXINTERVAL=15 I can see the
whole mollweide sphere.
My application use astronomic data then my shape files data are in sky
coordinates ( somenthing like Lon and Lat) .
If I draw using mapserver one of this shape (see LAYER "TestPoints") ,
the objects go in the right position in the Mollweide projection , the
only thing is that the grid and the data are not using the same projection.
I tried to use Aitoff projection too.
There isn't an epsg code for that, so I inserted one with an unused id .
But here too , in the layer definition I have to use epsg:4326 to plot
the points in the Aitoff projection but I am not able to draw the grid
sphere.
Thanks a lot
Antonio
LAYER
NAME "Grid"
METADATA
"DESCRIPTION" "Grid"
END
TYPE LINE
STATUS OFF
CLASS
NAME "Graticule"
COLOR 123 123 123
END
PROJECTION
"init=epsg:4326"
#"init=epsg:54009" # Mollweide
END
GRID
MAXARCS 2
# MAXINTERVAL 15000000
END
LAYER
NAME "TestPoints"
TYPE POLYGON
STATUS ON
DATA "TestPoints"
PROJECTION
"init=epsg:4326"
END
LABELITEM 'tilename'
DUMP true
CLASS
NAME "TestPoint"
STYLE
SIZE 2
OUTLINECOLOR 123 123 123
COLOR 0 0 255
END
LABEL
MINFEATURESIZE 200
END
END
METADATA
GML_INCLUDE_ITEMS "tilename,survey,ra,dec,nuvexptime,fuvexptime"
WMS_SERVER_VERSION "1.1.1"
WMS_FORMAT "image/png"
WMS_TITLE "Galex AIS Survey"
WMS_ABSTRACT "SDSS DR3 imaging level 0"
WMS_SRS "EPSG:54009"
WMS_NAME "TestPoint"
#WMS_FORCE_SEPARATE_REQUEST "0"
END
END
Brent Fraser wrote:
> Antonio,
> The values in the EXTENT must be in the units of the
> PROJECTION, so I'm suprised that with "UNITS dd" it works at
> all. The units of the MAP should be "UNITS meters". An
> EXTENT of
> "-18000000 -9000000 18000000 9000000" meters is an ok place
> to start when you want to show the entire globe.
> The GRID objects have sparse documentation. The MAXARCS
> object specifies the maximum number of lines you want shown
> on your map (in one direction), so MAXARCS 1 will try to
> draw only one line. From my notes MAXINTERVAL is "The
> maximum number of intervals to try to use. The distance
> between the lines, in layer(?) units. Most commonly changed
> parameter." Since its in the layer's units, using a
> MAXINTERVAL 15 with EPSG:54009 would try to draw a line
> every 15 meters (waay too many!), but with EPSG:4326 (a
> geographic coordinate system with units of degrees), it
> would try to draw one every 15 degrees (much more
> reasonable).
> Mapserver uses Proj4 for the coordinate systems
> operations. You may want to look on the Proj4 web site
> (http://proj.maptools.org/), but I believe it does support
> Aitoff.
> Brent Fraser
> GeoAnalytic Inc.
> Calgary, Alberta
> ----- Original Message -----
> From: "antonio" <volpicelli at OATO.INAF.IT>
> To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> Sent: Thursday, April 19, 2007 3:41 PM
> Subject: [UMN_MAPSERVER-USERS] Use of different epsg code
>> Hi ,
>> I am new of mapserver. I am using mapserver for an
> astronomic
>> application and I would like to use Mollweide projection
> ( epsg:54009).
>> I am able to draw the graticule ( the ellipse ) using
> this layer
>> inside mapfile.
>> First of all in the top of mapfile I defined these :
>> MAP
>> NAME ASTRO
>> STATUS ON
>> #EXTENT -180 -90 180 90 EXTENT -18000000 -9000000
> 18000000 9000000
>> UNITS dd
>> #IMAGECOLOR 0 123 123
>> TRANSPARENT ON
>> . PROJECTION
>> "init=epsg:54009"
>> END
>> The layer definition for the graticule:
>> LAYER
>> NAME "Grid"
>> METADATA
>> END
>> TYPE LINE
>> STATUS OFF
>> CLASS
>> NAME "Graticule"
>> COLOR 123 123 123
>> END
>> PROJECTION
>> "init=epsg:4326"
>> #"init=epsg:54009"
>> END
>> GRID
>> MAXARCS 1
>> MAXINTERVAL 15
>> END
>> END # Layer
>> So this work but I don't really understand why I have to
> define the
>> EXTENT as -18000000 -9000000 18000000 9000000 and not
> as -180 -90 180 90
>> and in the layer "Grid" definition I cannot define the
> init=epsg:54009
>> but init=epsg:4326 . If I use 54009 , mapserver goes in
> stall , it gets
>> 98% of CPU and don't end never.
>> If now I want draw one polygon shape on this map and I use
> this layer :
>> LAYER
>> NAME "TestPoint"
>> TYPE POLYGON
>> STATUS ON
>> DATA TestPoint
>> PROJECTION
>> "init=epsg:4326"
>> END
>> DUMP true
>> CLASS
>> NAME "TestPoint"
>> STYLE
>> SIZE 2
>> COLOR 0 0 255
>> END
>> LABEL
>> MINFEATURESIZE 200
>> END
>> END
>> METADATA
>> GML_INCLUDE_ITEMS
>> WMS_SRS "EPSG:4326"
>> #WMS_FORCE_SEPARATE_REQUEST "0" END
>> END
>> and here too , I have to use epsg:4326 and not 54009.
>> There are someone that could help me about this and If I
> want to change
>> the projection from Mollweide to Aitoff , is it possible
> and supported
>> by mapserver.
>> Thanks
>> Antonio
PLEASE WARNING: E-mail is CHANGED
volpicelli at oato.inaf.it
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070420/0e7f359a/attachment.html
