Bug ? : GetCapabilites
Yves Jacolin yjacolin at FREE.FR
Fri Apr 20 08:39:53 EDT 2007
Le Vendredi 20 Avril 2007 14:31, Frank Warmerdam a écrit :
> Yves Jacolin wrote:
> > Hi,
> > Somebody in a french forum got an error with mapserver. I tested it with
> > mapserv 4.10.1. The problem come from this line in the mapfile :
> > "wms_contactelectronicmailaddress" "email at domainname.fr"
> > the GetCapabilities, send this :
> > <Service>
> >     <ContactInformation>
> > <ContactElectronicMailAddress>email at domainname.fr</ContactElectronicMailA
> >ddress> </Service>
> > As you can see, the </ContactInformation> closed tag does not appear. Is
> > it a known bug ?
> Yves,
> It looks like this is still a bug in the dev version as well.  Reading the
> code I believe you can work around this problem by supplying either the
> "contactperson" or "contactorganization" metadata as well which causes a
> slightly different code path to be used.  I imagine this is why this hasn't
> already been commented on.
> Please file a bug on this I'm sure Assefa, Tom or someone will fix the
> code.
> Best regards,
Thanks, I will create the reports as soon as possible.
Y.
Yves Jacolin
http://yjacolin.gloobe.org
