Bug ? : GetCapabilites
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Fri Apr 20 22:23:49 EDT 2007
> Yves Jacolin wrote:
> > Hi,
> > Somebody in a french forum got an error with mapserver. I tested it
> > with mapserv 4.10.1. The problem come from this line in the
> mapfile :
> > "wms_contactelectronicmailaddress" "email at domainname.fr"
> > the GetCapabilities, send this :
> > <Service>
> > <ContactInformation>
> <ContactElectronicMailAddress>email at domainname.fr</ContactElectronicMa
> > ilAddress>
> > </Service>
> > As you can see, the </ContactInformation> closed tag does
> not appear.
> > Is it a known bug ?
> Yves,
> It looks like this is still a bug in the dev version as well.
> Reading the code I believe you can work around this problem
> by supplying either the "contactperson" or
> "contactorganization" metadata as well which causes a
> slightly different code path to be used. I imagine this is
> why this hasn't already been commented on.
> Please file a bug on this I'm sure Assefa, Tom or someone
> will fix the code.
Filed and accepted at http://trac.osgeo.org/mapserver/ticket/2070
..Tom
