Expression that detects patterns
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Sat Apr 21 09:56:32 EDT 2007
That's a limitation in the logical expression handler. You can't use regex [...] notation in an embedded regex. You can if the regex is a stand-along. For example:
CLASSITEM 'SUB'
CLASS
EXPRESSION /'[string]'/
END
That said I think you might need a different regex (you don't need the qoutes either). If you want all features where item foo starts with bar you'd do:
EXPRESSION /^bar/
If you want one where bar can be anywhere in foo use:
EXPRESSION /bar/
Steve
>>> Lawrence Hartpence <hartpence_gis at CO.JASPER.IA.US> 04/20/07 2:26 PM >>>
Hello.
I want to perform an ItemQuery that will find a certain string subset whether it
appears at the beginning, end or middle. I thought it was something like this:
('[SUB]' =~ /'[string]'/). I thought this was how you looked for a goroup of
letters, but MapServer thinks that [string] is an item. I used this expression
with some success: ('[SUB]' =~ /'.string.'/), but this does not give me
anything that starts or ends with the string; only cases where the string is in
the middle.
Any help in how to do this would be appreciated.
Lawrence Hartpence
