AW: [UMN_MAPSERVER-USERS] Error in drawquery with OracleSpatiall
Dominik Gierse gierse at SYSTEMTECHNIK.NET
Tue Apr 24 09:38:07 EDT 2007
Hi Fernando,
thanks for your reply.
I use a query to get information about the objects selected and
highlight these objects.
// resArr1 is an array with the ID´s selected
foreach($resArr1 as $ID) {
    @$mysearchLayer->queryByAttributes("EID", "EID = " . $ID,
MS_MULTIPLE);
$ANZ = $mysearchLayer->getNumResults();
//Setting the map-extends
$img = $gpoMap->drawQuery();     // this is the line with der Error
And here´s the log. Ist very long, but i dont want to delete important
information
First call with zoom
[Tue Apr 24 15:32:04 2007] [error] [client 127.0.0.1]
msOracleSpatialLayerOpen called with: GEOM FROM SDOUSER.TABLEITUNG USING
UNIQUE EID\r, referer: http://localhost/hst/map75.php
msOracleSpatialLayerOpen. Shared connection not available. Creating
one.\r, referer: http://localhost/hst/map75.php
msConnPoolRegister(tableitung,sdouser/sdouser at GIERSEDB,023F3660)\r,
msOracleSpatialLayerFreeItemInfo was called.\r, referer:
msOracleSpatialLayerInitItemInfo was called.\r, referer:
msOracleSpatialLayerWhichShapes was called.\r, referer:
msOracleSpatialLayerWhichShapes. Using this Sql to retrieve the data:
SELECT EID, SK, GEOM FROM SDOUSER.TABLEITUNG WHERE SDO_FILTER( GEOM,
MDSYS.SDO_GEOMETRY(2003, NULL,
NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(340895
3.56,5712292.86,3409605.88,5712782.1) ),'querytype=window') = 'TRUE'\r,
msOracleSpatialLayerClose was called. Layer connection:
sdouser/sdouser at GIERSEDB\r, referer: http://localhost/hst/map75.php
msOracleSpatialLayerClose. Cleaning layerinfo handlers.\r, referer:
msOracleSpatialLayerClose. Cleaning Oracle handlers.\r, referer:
msConnPoolRelease(tableitung,sdouser/sdouser at GIERSEDB,023F3660)\r,
msConnPoolClose(sdouser/sdouser at GIERSEDB,023F3660)\r, referer:
Second call with query
[Tue Apr 24 15:32:57 2007] [error] [client 127.0.0.1]
msConnPoolRegister(tableitung,sdouser/sdouser at GIERSEDB,021E8588)\r,
NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(340930
8.86,5712666.1,3409328.86,5712686.1) ),'querytype=window') = 'TRUE'\r,
msConnPoolRelease(tableitung,sdouser/sdouser at GIERSEDB,021E8588)\r,
msConnPoolClose(sdouser/sdouser at GIERSEDB,021E8588)\r, referer:
msConnPoolRegister(tableitung,sdouser/sdouser at GIERSEDB,02644528)\r,
msOracleSpatialLayerGetItems was called.\r, referer:
msOracleSpatialLayerGetShape was called. Using the record = 38752.\r,
msOracleSpatialLayerGetShape. Sql: SELECT X_MANUEL, NAME, LAENGE, SK,
EID, SCHACHTOBE, SCHACHTUNT, STRASSE, MATERIAL, PROFILART, PROFILBREI,
PROFILHOEH, BAUJAHR, HYDRANG, KOSTENSTEL, X1, Y1, X2, Y2, OBEN, UNTEN,
ENTWAESSER, SOHLEOBEN, SOHLEUNTEN, NETZ, GEOM FROM SDOUSER.TABLEITUNG
WHERE EID = 38752\r, referer: http://localhost/hst/map75.php
msConnPoolRelease(tableitung,sdouser/sdouser at GIERSEDB,02644528)\r,
msConnPoolClose(sdouser/sdouser at GIERSEDB,02644528)\r, referer:
msConnPoolRegister(tableitung,sdouser/sdouser at GIERSEDB,02621B50)\r,
SELECT EID, SK, EID, GEOM FROM SDOUSER.TABLEITUNG WHERE EID = 38752 AND
SDO_FILTER( GEOM, MDSYS.SDO_GEOMETRY(2003, NULL,
NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(340466
2,5706718.13,3418395,5717017.88) ),'querytype=window') = 'TRUE'\r,
msConnPoolRelease(tableitung,sdouser/sdouser at GIERSEDB,02621B50)\r,
msConnPoolClose(sdouser/sdouser at GIERSEDB,02621B50)\r, referer:
msConnPoolRegister(tableitung,sdouser/sdouser at GIERSEDB,026136F8)\r,
msConnPoolRelease(tableitung,sdouser/sdouser at GIERSEDB,026136F8)\r,
msConnPoolClose(sdouser/sdouser at GIERSEDB,026136F8)\r, referer:
Best regards
Dominik Gierse, Dipl. Ing. (FH)
Softwareentwicklung
mailto:gierse at systemtechnik.net
Tel./Fax: +49 291 9929-70 / 7691
Sitz der Gesellschaft:
HST Hydro-Systemtechnik GmbH
Sophienweg 3
D-59872 Meschede, Germany
Tel./Fax: +49 291 9929-0 / 7691
http://www.systemtechnik.net
Geschäftsführer: Dipl.-Ing. Martin Frigger, Dipl.-Ing. Richard Ernst
Registergericht: Amtsgericht Arnsberg - HRB 3396
UST-IDNR.: DE 191 917 337
Steuer-Nr.: 334 5706 0269
