[UMN_MAPSERVER-USERS] Variable substitution
Richard Duivenvoorde rdmailings at DUIF.NET
Tue Apr 24 16:50:40 EDT 2007
Uhm, very interesting. I it working?
I'll cc this to the list also.
Richard
Léveillé wrote:
> Hi Richard,
> Here is something very interesting that solved my problem - might help you
> as well ...
> http://mapserver.gis.umn.edu/docs/reference/cgi/referencemanual-all-pages
> See section "Changing map file parameters via a form or a URL"
> ______________________________________________________
> JAMES LÉVEILLÉ
> Service des systèmes de Mission
> Direction des technologies de l'information
> Ministère des Transports du Québec
> 5833, boul. Pierre-Bertrand, 2ième étage
> Québec (Québec) G2K 1K7
> Téléphone:   (418) 380-2005 poste 227
> Télécopieur: (418) 644-6653
> james.leveille at mtq.gouv.qc.ca
> -----Message d'origine-----
> De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la
> part de Richard Duivenvoorde
> Envoyé : 24 avril 2007 16:29
> À : MAPSERVER-USERS at LISTS.UMN.EDU
> Objet : Re: [UMN_MAPSERVER-USERS] Variable substitution
> Hi James,
> I've been fiddling with this also. But in
> http://mapserver.gis.umn.edu/docs/reference/mapfile/variable_sub/
> it states that since Mapserver 4.10.1 the only keywords that support
> variable substitution are: DATA TILEINDEX CONNECTION FILTER and EXPRESSION
> Don't know if somebody can confirm that?
> Léveillé wrote:
>> Hi,
>> I am trying to place a string at a known position.
>> The string must be passed in the URL (variable substitution).
>> I was able to use variable substitution with the FILTER tag. But in
>> this case, I can't make it work with the TEXT tag and found nothing on
>> the list.
>> Anybody knows how to do it ??
>> Regards
>>   LAYER
>>     NAME                  "mylayer"
>>     STATUS                ON
>>     DUMP                  TRUE
>>     EXTENT                30000 75000 1700000 2120000
>>     TYPE                  ANNOTATION
>>     CONNECTIONTYPE        OGR
>>     CONNECTION            "data\mytab.tab"
>>     TRANSFORM             FALSE
>>     FORCE                 TRUE
>>     CLASS
>>       TEXT                "%xxx%"
>>       LABEL
>>         TYPE              TRUETYPE
>>         FONT              "verdana"
>>         SIZE              10
>>         POSITION          LR
>>         COLOR             0 0 0
>>         OUTLINECOLOR      255 255 255
>>         FORCE             TRUE
>>       END
>>     END
>>   END
>> *JAMES LÉVEILLÉ
>> *Service des systèmes de Mission
>> james.leveille at mtq.gouv.qc.ca <mailto:james.leveille at mtq.gouv.qc.ca>
