Simplified state outline data?
Jeff Dege jdege at KORTERRA.COM
Wed Apr 25 10:25:57 EDT 2007
We're not running PostGIS, we're not running PostgresSQL.
Though we may start, if this turns out to be the easiest way to handle
these problems.
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Aaron Racicot
> Sent: Tuesday, April 24, 2007 7:18 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Simplified state outline data?
> You can load [1] the data into PostGIS and use the simplify
> function [2] to
> create a simplified geometry, and even dump back to shapefile
> [3] if you
> wish.
> [1] - http://postgis.refractions.net/docs/ch04.html#id2707142
> [2] - http://postgis.refractions.net/docs/ch06.html#id2712912
> [3] - http://postgis.refractions.net/docs/ch04.html#id2707567
> A
>  Aaron Racicot - GIS Programmer
>  360.221.2441 - aaronr at ecotrust.org
>  e c o t r u s t
>  pobox 1614
>  langley wa 98260
>  www.ecotrust.org
> Behalf Of Jeff Dege
> Sent: Tuesday, April 24, 2007 3:08 PM
> Subject: [UMN_MAPSERVER-USERS] Simplified state outline data?
> We have an app that needs to generate a map with state outlines, but
> needs to keep the total amount of data as small as possible.
> Fortunately, we don't need precision, a rough approximation of the
> outlines is fine.
> Does anyone know of a source of approximate state outline data?
> Alternatively, does anyone know of a tool I can use to reduce
> the number
> of points in a geometric feature, while retaining the general outline?
> Something that would take a complicated boundary drawn with
> points every
> 100 meters and return a simplified boundary drawn with points every 10
> kilometers?
