Simplified state outline data?
Rahkonen Jukka
Jukka.Rahkonen at MMMTIKE.FI
Wed Apr 25 10:36:51 EDT 2007
Open Jump (www.openjump.org) seems to have a couple or menu selections for generalisation and it reads (and writes) shapefiles. I have never tried those tools myself, though.
-Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] Puolesta Jeff Dege
> Lähetetty: 25. huhtikuuta 2007 17:26
> Vastaanottaja: MAPSERVER-USERS at LISTS.UMN.EDU
> Aihe: Re: [UMN_MAPSERVER-USERS] Simplified state outline data?
> We're not running PostGIS, we're not running PostgresSQL.
> Though we may start, if this turns out to be the easiest way
> to handle these problems.
> > -----Original Message-----
> > From: UMN MapServer Users List
> > [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Aaron Racicot
> > Sent: Tuesday, April 24, 2007 7:18 PM
> > To: MAPSERVER-USERS at LISTS.UMN.EDU
> > Subject: Re: [UMN_MAPSERVER-USERS] Simplified state outline data?
> > You can load [1] the data into PostGIS and use the simplify
> function
> > [2] to create a simplified geometry, and even dump back to
> shapefile
> > [3] if you wish.
> > [1] - http://postgis.refractions.net/docs/ch04.html#id2707142
> > [2] - http://postgis.refractions.net/docs/ch06.html#id2712912
> > [3] - http://postgis.refractions.net/docs/ch04.html#id2707567
> > A
> > Aaron Racicot - GIS Programmer
> > 360.221.2441 - aaronr at ecotrust.org
> > e c o t r u s t
> > pobox 1614
> > langley wa 98260
> > www.ecotrust.org
> > [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Jeff Dege
> > Sent: Tuesday, April 24, 2007 3:08 PM
> > Subject: [UMN_MAPSERVER-USERS] Simplified state outline data?
> > We have an app that needs to generate a map with state
> outlines, but
> > needs to keep the total amount of data as small as possible.
> > Fortunately, we don't need precision, a rough approximation of the
> > outlines is fine.
> > Does anyone know of a source of approximate state outline data?
> > Alternatively, does anyone know of a tool I can use to reduce the
> > number of points in a geometric feature, while retaining
> the general
> > outline?
> > Something that would take a complicated boundary drawn with points
> > every 100 meters and return a simplified boundary drawn with points
> > every 10 kilometers?
