EPSG code of 32618 for WGS 84 / UTM zone 18N
Frank Warmerdam
warmerdam at POBOX.COM
Wed Apr 25 13:06:11 EDT 2007
John Mitchell wrote:
> Hi,
> I have the listed the gdalinfo listing of an erdas imagine file below
> and notice that it does not have a EPSG code within it. I need this
> EPSG code if I want to reproject within gdalwarp or for on the fly
> projection within mapserver. Based the gdalinfo listing I searched
> within the epsg file and found the following code and definition:
> # WGS 84 / UTM zone 18N
> <32618> +proj=utm +zone=18 +ellps=WGS84 +datum=WGS84 +units=m +no_defs <>
> Does the above EPSG code of 32618 make sense for the below gdalinfo listing?
John,
Yes, EPSG:32618 is equivelent to the following definition.
Best regards,
> PROJCS["UTM Zone 18, Northern Hemisphere",
> GEOGCS["WGS_1984",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.2572235630016],
> TOWGS84[0,0,0,0,0,0,0]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",-75],
> PARAMETER["scale_factor",0.9996],
> PARAMETER["false_easting",500000],
> PARAMETER["false_northing",0],
> UNIT["Meter",1]]
and watch the world go round - Rush | President OSGeo, http://osgeo.org
