Simplified state outline data?
David William Bitner
david.bitner at GMAIL.COM
Wed Apr 25 15:25:04 EDT 2007
Although if you are not using Topology, this will likely lead to lots of
slivers between the states.
On 4/24/07, Aaron Racicot <aaronr at z-pulley.com> wrote:
> You can load [1] the data into PostGIS and use the simplify function [2]
> to
> create a simplified geometry, and even dump back to shapefile [3] if you
> wish.
> [1] - http://postgis.refractions.net/docs/ch04.html#id2707142
> [2] - http://postgis.refractions.net/docs/ch06.html#id2712912
> [3] - http://postgis.refractions.net/docs/ch04.html#id2707567
> A
> Aaron Racicot - GIS Programmer
> 360.221.2441 - aaronr at ecotrust.org
> e c o t r u s t
> pobox 1614
> langley wa 98260
> www.ecotrust.org
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Jeff Dege
> Sent: Tuesday, April 24, 2007 3:08 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] Simplified state outline data?
> We have an app that needs to generate a map with state outlines, but
> needs to keep the total amount of data as small as possible.
> Fortunately, we don't need precision, a rough approximation of the
> outlines is fine.
> Does anyone know of a source of approximate state outline data?
> Alternatively, does anyone know of a tool I can use to reduce the number
> of points in a geometric feature, while retaining the general outline?
> Something that would take a complicated boundary drawn with points every
> 100 meters and return a simplified boundary drawn with points every 10
> kilometers?
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070425/cc50a190/attachment.html
