classification doesn't work with floating points
Steven M. Ottens
steven.ottens at GEODAN.NL
Thu Apr 26 05:50:12 EDT 2007
Hi all,
I'm working on a dynamic classification application which works with
SLD. I select a bounding box and Mapserver generates a new SLD with the
minimum and maximum values and a range of classes between. This works
fine and the SLD is correct with all the expected classes. However if I
use that SLD to generate a new map I only see 3 colours instead of the
expected 50.
After some investigation I discovered that it was due to the very small
classes I get:
<ColorMapEntry color="#0c317c" quantity="-6.75" />
<ColorMapEntry color="#0f377c" quantity="-6.54" />
<ColorMapEntry color="#0f407e" quantity="-6.47" />
<ColorMapEntry color="#11497f" quantity="-6.40" />
<ColorMapEntry color="#12527f" quantity="-6.36" />
<ColorMapEntry color="#145a81" quantity="-6.32" />
<ColorMapEntry color="#166482" quantity="-6.29" />
<ColorMapEntry color="#186c83" quantity="-6.27" />
<ColorMapEntry color="#1a7584" quantity="-6.25" />
<ColorMapEntry color="#1c7e85" quantity="-6.24" />
<ColorMapEntry color="#1d8786" quantity="-6.23" />
<ColorMapEntry color="#1f9087" quantity="-6.22" />
<ColorMapEntry color="#219888" quantity="-6.21" />
<ColorMapEntry color="#239e89" quantity="-6.20" />
<ColorMapEntry color="#26a380" quantity="-6.19" />
<ColorMapEntry color="#2caa74" quantity="-6.18" />
<ColorMapEntry color="#31b068" quantity="-6.17" />
<ColorMapEntry color="#36b75c" quantity="-6.16" />
<ColorMapEntry color="#3cbe50" quantity="-6.15" />
<ColorMapEntry color="#42c444" quantity="-6.14" />
<ColorMapEntry color="#48cb38" quantity="-6.13" />
<ColorMapEntry color="#4dd12c" quantity="-6.12" />
<ColorMapEntry color="#53d81f" quantity="-6.11" />
<ColorMapEntry color="#58de14" quantity="-6.10" />
<ColorMapEntry color="#5ee508" quantity="-6.09" />
<ColorMapEntry color="#61e901" quantity="-6.08" />
<ColorMapEntry color="#72ea01" quantity="-6.07" />
<ColorMapEntry color="#8bed02" quantity="-6.06" />
<ColorMapEntry color="#a2f002" quantity="-6.05" />
<ColorMapEntry color="#b9f102" quantity="-6.04" />
<ColorMapEntry color="#d1f402" quantity="-6.02" />
<ColorMapEntry color="#e9f602" quantity="-6.01" />
<ColorMapEntry color="#fcf803" quantity="-5.99" />
<ColorMapEntry color="#faf105" quantity="-5.97" />
<ColorMapEntry color="#f6e808" quantity="-5.94" />
<ColorMapEntry color="#f3de0c" quantity="-5.90" />
<ColorMapEntry color="#f0d50f" quantity="-5.85" />
<ColorMapEntry color="#eccc13" quantity="-5.75" />
<ColorMapEntry color="#e9c316" quantity="-5.63" />
<ColorMapEntry color="#000000" quantity="-5.52" />
<ColorMapEntry color="#e2b01c" quantity="-5.35" />
<ColorMapEntry color="#ff1b1b" quantity="-5.00" />
<ColorMapEntry color="#ffa720" quantity="350.00" />
If the classes are without floats there's no problem and mapserver works
as expected.
Some more investigation showed that the 3 colours I see are the ones from:
The last being the class everything bigger then -5.
It's striking that the other two are both around the .5, which does make
me believe there's something wrong with the floating point handling of
mapserver with regard of drawing maps. Is there a setting in my mapfile
which I have to set to make sure it will use all decimals to do the
rendering?
I've attached the map file of this particular layer. In there you see
multiple layers with the same classification, each is an aggregation of
the previous one and kicks in at a different scale level. The whole
thing is a detailed DEM of the Netherlands.
Regards,
Steven
MAP
EXTENT 10000 305000 280000 619000
UNITS METERS
NAME "_EduGIS_hoogte"
SHAPEPATH "D:/wwwsoft/mapserver/data/hoogte/nederland"
PROJECTION
"init=EPSG:28992"
END
LEGEND
IMAGECOLOR 255 255 255
KEYSIZE 18 12
KEYSPACING 5 5
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 0 0 89
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
END
POSITION LL
STATUS ON
END #legend
QUERYMAP
COLOR 255 0 0
SIZE -1 -1
STATUS OFF
STYLE HILITE
END #querymap
WEB
IMAGEPATH "D:\temp"
IMAGEURL "/temp/"
MAXSCALE 30000000
MINSCALE 1000
METADATA
WMS_TITLE "EduGIS Algemeen Hoogtebestand Nederland (Ooijpolder en Ronde Venen)"
WMS_ABSTRACT "EduGIS Algemeen Hoogtebestand Nederland (Ooijpolder en Ronde Venen)"
WMS_ONLINERESOURCE "/cgi-bin/edugis/mapserv.cgi?map=maps/edugis/hoogte.map"
WMS_SRS "EPSG:28992"
END
END # web
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE PC256
EXTENSION "png"
END # outputformat
LAYER
GROUP "hoogtes"
NAME "HoogteMaxRes"
METADATA
WMS_TITLE "Hoogte Max Res"
WMS_ABSTRACT "Hoogte Max Res"
WMS_NAME "Hoogte Max Res"
WFS_TITLE "Hoogte Max Res"
# gml_include_items "value_0"
# gml_value_0_alias "hoogte"
WMS_GROUP_TITLE "hoogte"
END
PROJECTION
"init=epsg:28992"
END
DATA "d:/wwwsoft/mapserver/data/hoogte/nederland/overview.tif"
STATUS ON
DUMP TRUE
#TEMPLATE "blank.html"
TYPE RASTER
UNITS METERS
PROCESSING "SCALE=-10,400"
PROCESSING "SCALE_BUCKETS=410"
MINSCALE 500000
MAXSCALE 30000000
CLASSITEM "[pixel]"
CLASS NAME '-12 - -7 m' EXPRESSION ( [pixel] >= -12 AND [pixel] < -7 ) COLOR 12 49 124 END
CLASS NAME '-7 - -6 m' EXPRESSION ( [pixel] >= -7 AND [pixel] < -6 ) COLOR 15 55 124 END
CLASS NAME '-6 - -5 m' EXPRESSION ( [pixel] >= -6 AND [pixel] < -5 ) COLOR 15 64 126 END
CLASS NAME '-5 - -4 m' EXPRESSION ( [pixel] >= -5 AND [pixel] < -4 ) COLOR 17 73 127 END
CLASS NAME '-4 - -3 m' EXPRESSION ( [pixel] >= -4 AND [pixel] < -3 ) COLOR 18 82 127 END
CLASS NAME '-3 - -2,5 m' EXPRESSION ( [pixel] >= -3 AND [pixel] < -2.5 )COLOR 20 90 129 END
CLASS NAME '-2,5 - -2 m' EXPRESSION ( [pixel] >= -2.5 AND [pixel] < -2 )COLOR 22 100 130 END
CLASS NAME '-2 - -1,5 m' EXPRESSION ( [pixel] >= -2 AND [pixel] < -1.5 )COLOR 24 108 131 END
CLASS NAME '-1,5 - -1 m' EXPRESSION ( [pixel] >= -1.5 AND [pixel] < -1 )COLOR 26 117 132 END
CLASS NAME '-1 - -0,5 m' EXPRESSION ( [pixel] >= -1 AND [pixel] < -0.5 )COLOR 28 126 133 END
CLASS NAME '-0,5 - 0 m' EXPRESSION ( [pixel] >= -0.5 AND [pixel] < 0 ) COLOR 29 135 134 END
CLASS NAME ' 0 - 0,5 m' EXPRESSION ( [pixel] >= 0 AND [pixel] < 0.5 ) COLOR 31 144 135 END
CLASS NAME ' 0,5 - 1 m' EXPRESSION ( [pixel] >= 0.5 AND [pixel] < 1 ) COLOR 33 152 136 END
CLASS NAME ' 1 - 1,5 m' EXPRESSION ( [pixel] >= 1 AND [pixel] < 1.5 ) COLOR 35 158 137 END
CLASS NAME ' 1,5 - 2 m' EXPRESSION ( [pixel] >= 1.5 AND [pixel] < 2 ) COLOR 38 163 128 END
CLASS NAME ' 2 - 2,5 m' EXPRESSION ( [pixel] >= 2 AND [pixel] < 2.5 ) COLOR 44 170 116 END
CLASS NAME ' 2,5 - 3 m' EXPRESSION ( [pixel] >= 2.5 AND [pixel] < 3 ) COLOR 49 176 104 END
CLASS NAME ' 3 - 3,5 m' EXPRESSION ( [pixel] >= 3 AND [pixel] < 3.5 ) COLOR 54 183 92 END
CLASS NAME ' 3,5 - 4 m' EXPRESSION ( [pixel] >= 3.5 AND [pixel] < 4 ) COLOR 60 190 80 END
CLASS NAME ' 4 - 4,5 m' EXPRESSION ( [pixel] >= 4 AND [pixel] < 4.5 ) COLOR 66 196 68 END
CLASS NAME ' 4,5 - 5 m' EXPRESSION ( [pixel] >= 4.5 AND [pixel] < 5 ) COLOR 72 203 56 END
CLASS NAME ' 5 - 6 m' EXPRESSION ( [pixel] >= 5 AND [pixel] < 6 ) COLOR 77 209 44 END
CLASS NAME ' 6 - 7 m' EXPRESSION ( [pixel] >= 6 AND [pixel] < 7 ) COLOR 83 216 31 END
CLASS NAME ' 7 - 8 m' EXPRESSION ( [pixel] >= 7 AND [pixel] < 8 ) COLOR 88 222 20 END
CLASS NAME ' 8 - 9 m' EXPRESSION ( [pixel] >= 8 AND [pixel] < 9 ) COLOR 94 229 8 END
CLASS NAME ' 9 - 10 m' EXPRESSION ( [pixel] >= 9 AND [pixel] < 10 ) COLOR 97 233 1 END
CLASS NAME ' 10 - 12 m' EXPRESSION ( [pixel] >= 10 AND [pixel] < 12 ) COLOR 114 234 1 END
CLASS NAME ' 12 - 14 m' EXPRESSION ( [pixel] >= 12 AND [pixel] < 14 ) COLOR 139 237 2 END
CLASS NAME ' 14 - 16 m' EXPRESSION ( [pixel] >= 14 AND [pixel] < 16 ) COLOR 162 240 2 END
CLASS NAME ' 16 - 18 m' EXPRESSION ( [pixel] >= 16 AND [pixel] < 18 ) COLOR 185 241 2 END
CLASS NAME ' 18 - 20 m' EXPRESSION ( [pixel] >= 18 AND [pixel] < 20 ) COLOR 209 244 2 END
CLASS NAME ' 20 - 25 m' EXPRESSION ( [pixel] >= 20 AND [pixel] < 25 ) COLOR 233 246 2 END
CLASS NAME ' 25 - 30 m' EXPRESSION ( [pixel] >= 25 AND [pixel] < 30 ) COLOR 252 248 3 END
CLASS NAME ' 30 - 35 m' EXPRESSION ( [pixel] >= 30 AND [pixel] < 35 ) COLOR 250 241 5 END
CLASS NAME ' 35 - 40 m' EXPRESSION ( [pixel] >= 35 AND [pixel] < 40 ) COLOR 246 232 8 END
CLASS NAME ' 40 - 45 m' EXPRESSION ( [pixel] >= 40 AND [pixel] < 45 ) COLOR 243 222 12 END
CLASS NAME ' 45 - 50 m' EXPRESSION ( [pixel] >= 45 AND [pixel] < 50 ) COLOR 240 213 15 END
CLASS NAME ' 50 - 60 m' EXPRESSION ( [pixel] >= 50 AND [pixel] < 60 ) COLOR 236 204 19 END
CLASS NAME ' 60 - 70 m' EXPRESSION ( [pixel] >= 60 AND [pixel] < 70 ) COLOR 233 195 22 END
CLASS NAME ' 70 - 80 m' EXPRESSION ( [pixel] >= 70 AND [pixel] < 80 ) COLOR 230 185 25 END
CLASS NAME ' 80 - 90 m' EXPRESSION ( [pixel] >= 80 AND [pixel] < 90 ) COLOR 226 176 28 END
CLASS NAME ' 90 - 100 m' EXPRESSION ( [pixel] >= 90 AND [pixel] < 100 ) COLOR 223 167 32 END
CLASS NAME ' 100 - 125 m' EXPRESSION ( [pixel] >= 100 AND [pixel] < 125 )COLOR 219 158 35 END
CLASS NAME ' 125 - 150 m' EXPRESSION ( [pixel] >= 125 AND [pixel] < 150 )COLOR 216 149 38 END
CLASS NAME ' 150 - 175 m' EXPRESSION ( [pixel] >= 150 AND [pixel] < 175 )COLOR 213 139 42 END
CLASS NAME ' 175 - 200 m' EXPRESSION ( [pixel] >= 175 AND [pixel] < 200 )COLOR 210 130 45 END
CLASS NAME ' 200 - 250 m' EXPRESSION ( [pixel] >= 200 AND [pixel] < 250 )COLOR 206 121 48 END
CLASS NAME ' 250 - 300 m' EXPRESSION ( [pixel] >= 250 AND [pixel] < 300 )COLOR 203 111 51 END
CLASS NAME ' 300 - 350 m' EXPRESSION ( [pixel] > 300) COLOR 200 102 54 END
END # layer hoogte
LAYER
GROUP "hoogtes"
NAME "Hoogte100m"
METADATA
WMS_TITLE "Hoogte 100m"
WMS_ABSTRACT "Hoogte 100m"
WMS_NAME "Hoogte 100m"
WFS_TITLE "Hoogte 100m"
END
PROJECTION
"init=epsg:28992"
END
TILEINDEX ahn100_index
TILEITEM "Location"
STATUS ON
DUMP TRUE
TYPE RASTER
UNITS METERS
MINSCALE 150000
MAXSCALE 500000
CLASSITEM "[pixel]"
END # layer hoogte
LAYER
GROUP "hoogtes"
NAME "Hoogte25m"
METADATA
WMS_TITLE "Hoogte 25m"
WMS_ABSTRACT "Hoogte 25m"
WMS_NAME "Hoogte 25m"
WFS_TITLE "Hoogte 25m"
END
PROJECTION
"init=epsg:28992"
END
TILEINDEX ahn25_index
TILEITEM "location"
STATUS ON
DUMP TRUE
TYPE RASTER
UNITS METERS
MINSCALE 30000
MAXSCALE 150000
CLASSITEM "[pixel]"
END # layer hoogte
LAYER
GROUP "hoogtes"
NAME "Hoogte"
METADATA
WMS_TITLE "Hoogte 5m"
WMS_ABSTRACT "Hoogte 5m"
WMS_NAME "Hoogte 5m"
WFS_TITLE "Hoogte 5m"
END
PROJECTION
"init=epsg:28992"
END
TILEINDEX ahn5_index.shp
TILEITEM "Location"
STATUS ON
DUMP TRUE
TYPE RASTER
UNITS METERS
MINSCALE 1000
MAXSCALE 30000
CLASSITEM "[pixel]"
END # layer hoogte
#### The following layers serve as reference:
LAYER
NAME "_top250vlakken"
GROUP "Referentielijnen"
METADATA
WMS_TITLE "top250 vlakken"
WMS_ABSTRACT "top250 vlakken"
WMS_GROUP_TITLE "Referentielijnen"
END
PROJECTION
"init=epsg:28992"
END
DATA "geom from top250_vlakken"
CONNECTION "user=edugis password=edugis dbname=edugisdb1 host=localhost port=5432"
CONNECTIONTYPE postgis
PROCESSING "CLOSE_CONNECTION=DEFER"
TYPE POLYGON
UNITS METERS
MAXSCALE 150000
MINSCALE 50000
SIZEUNITS PIXELS
TOLERANCE 0
TOLERANCEUNITS PIXELS
CLASS
STYLE
OUTLINECOLOR 160 160 160
END
END
END # layer top250vlakken
LAYER
NAME "_top250lijnen"
METADATA
WMS_TITLE "top250 lijnen"
WMS_ABSTRACT "top250 lijnen"
END
PROJECTION
"init=epsg:28992"
END
DATA "geom from top250_lijnen"
TYPE LINE
UNITS METERS
MAXSCALE 150000
MINSCALE 50000
SIZEUNITS PIXELS
TOLERANCE 0
CLASS
STYLE
END
END
END #layer top250lijnen
LAYER
NAME "_top50vlakken"
METADATA
WMS_TITLE "top50 vlakken"
WMS_ABSTRACT "top50 vlakken"
END
PROJECTION
"init=epsg:28992"
END
DATA "geom from top050_vlakken"
TYPE POLYGON
UNITS METERS
MAXSCALE 49999
MINSCALE 1000
SIZEUNITS PIXELS
TOLERANCE 0
CLASS
STYLE
END
END
END #layer top50vlakken
LAYER
NAME "_top50lijnen"
METADATA
WMS_TITLE "top50 lijnen"
WMS_ABSTRACT "top50 lijnen"
END
PROJECTION
"init=epsg:28992"
END
DATA "geom from top050_lijnen"
TYPE LINE
UNITS METERS
MAXSCALE 49999
MINSCALE 1000
SIZEUNITS PIXELS
TOLERANCE 0
CLASS
STYLE
END
END #layer top50lijnen
END
END #map
