Class order in mapfile
Bart van den Eijnden (OSGIS)
bartvde at OSGIS.NL
Thu Apr 26 06:52:23 EDT 2007
Sortshp can do this for shapefiles, see:
http://mapserver.gis.umn.edu/docs/reference/utilityreference/sortshp
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Gregor Mosheh <gregor at HOSTGIS.COM>
Naar: MAPSERVER-USERS at LISTS.UMN.EDU <MAPSERVER-USERS at LISTS.UMN.EDU>
Onderwerp: Re: [UMN_MAPSERVER-USERS] Class order in mapfile
Datum: 26/04/07 08:51
> > If I understand correctly, classes in a layer are not rendered in the
> > order they appear in the layer, but as they are encountered in the
> > dataset, e.g. a shapefile.
> Correct. Features are rendered in the order they appear in the data
> source. The selection of class for a feature is a first-match based on the
> classes' criteria.
> > A workaround could for instance be seperating classes into layers.
> > Any other workarounds?
> Another could be to sort your dataset to fit your classes. Using
> PostgreSQL, the CLUSTER command will physically sort a table by the given
> criteria. There may or may not be something you could do with shapefiles
> to accomplish this same goal. (in a pinch, I suppose you could shp2pgsql,
> cluster, pgsql2shp)
> HostGIS
> Cartographic development and hosting services
> 707-822-9355
> http://www.HostGIS.com/
> "Remember that no one cares if you can back up, only if you can
restore."
> - AMANDA
