Zoom To Scale
Tamas Szekeres szekerest at GMAIL.COM
Wed Aug 1 05:22:12 EDT 2007
David,
Did you use the mapObj.zoomScale method?
Best regards,
Tamas
2007/7/31, David Hober <dhober at geographit.com>:
> Greetings,
> I'm having some trouble trying to achieve a zoom to scale effect in a
> mapping program.
> I'm using mapscript's c# library, version 4.10.
> I tried setting the map object's scale property, but that had no effect, so
> I'm trying to achieve it now by resetting the extent of the map.
> The method that does the calculation receives a fractional scale value (say,
> 50000).  I calculate the center point in map units, but I just can't figure
> out how to scale the extent to achieve the user-provided scale value.
> I'm open for any suggestions / ideas.
> -- Dave
