error compile mapserver
Gregor Mosheh
gregor at HOSTGIS.COM
Sat Aug 4 06:53:52 EDT 2007
Bayu Kurniawan R wrote:
> error compiling mapserver-4.10.2
> Warning: dl() [function.dl]: Unable to load dynamic library
> '/usr/local/lib/php/ext/php_mapscript.so' - libiconv.so.2: cannot open
> shared object file: No such file or directory in
> /media/hda6/htdocs/mapscript.php on line 2
I take it from your meessage that this isn't a problem with compiling
Mapserver, but of PHP/Mapscript being loaded at runtime.
As it says: The library libiconv could not be found. Either it isn't
installed, or else you need to re-run "ldconfig" to update your linker.
Try this:
locate libiconv.so.2 # that tells you whether it exists
ldconfig -p | grep iconv # that tells whether the linker is finding it
ldconfig # that will cause the linker to check for new libraries
Gregor Mosheh / Greg Allensworth
System Administrator, HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
only if you can restore." - AMANDA
