Transparency in WMS
Daniel Morissette dmorissette at MAPGEARS.COM
Tue Aug 7 08:57:34 EDT 2007
Jacolin Yves wrote:
> Le Tuesday 07 August 2007 14:37:59 Daniel Morissette, vous avez écrit :
>> If you are using MapServer as a WMS service and expecting the
>> transparency/opacity of a given layer to result in a 50% opaque GetMap
>> response then that won't work.
> Is it a limitation from mapserver or from the standard itself?
It's a bit of both.
The WMS spec is not clear on whether it is acceptable to return
semi-transparent images. Section 7.2.3.9 of the WMS 1.1.1 spec talks
about the TRANSPARENT=TRUE/FALSE GetMap parameter but that is only to
control whether the background of the image is fully transparent or not
and does not address the possibility of producing semi-transparent
images. Everywhere else it suggests that pixels representing features
are fully opaque.
And it may also be a MapServer limitation in the sense that we may need
to make some changes to allow MapServer to generate semi-transparent
images... but maybe not and that works already, I just haven't checked.
Daniel
Daniel Morissette
http://www.mapgears.com/
