MapServer Performance Tips
Paul Ramsey pramsey at REFRACTIONS.NET
Tue Aug 7 18:26:30 EDT 2007
Tim,
You're getting some good advice on mapfile layout, which can be
summarized as "don't draw features that you cannot see, or don't need to
see". So don't draw 500K roads into a 1000x1000 image, because each road
will barely take up a pixel, it's a waste of CPU time.
Since you're using Oracle, if you want performance, you *MUST* do the
following:
* Run Mapserver as a fastcgi process
* Use CLOSE_CONNECTION=DEFER as a processing instruction at the end of
your Oracle layers
Otherwise the connection overhead will kill you.
Also watch out for using "init=epsg:xxxx" PROJECTION strings, as
Mapserver opens and reads the epsg file for each one of them.  Better to
just spell out the whole projection.  This can be a huge win on maps
with piles of layers.
Paul
Timothy J Nolte wrote:
> Now that I finally have MapServer talking to our Oracle database my next big
> issue is performance. Does anyone have any tips on MapServer performance?
> We're running MapServer on:
> 	Sun e450
> 	4 x 400MHz Sparc II Processors
> 	4GB ram
> I have around 42GB of map data I'm trying to serve up. I'm not seeing the
> greatest performance. Are there any key things I need to remember with the
> setup of my Shapefile data? Are there certain things I should do with my
> .map file to help performance? Anyone using the DM Solutions US Streets
> data, any issues with performance there? What kind of hardware are others
> running on? Thanks.
   Paul Ramsey
   Refractions Research
   http://www.refractions.net
   pramsey at refractions.net
   Phone: 250-383-3022
   Cell: 250-885-0632
