use of shp2tile and ogrtindex
Gambin Dejan
Dejan.Gambin at PULA.HR
Thu Aug 9 06:46:13 EDT 2007
Hi Antonio,
gdaltindex is used for building a shapefile as a raster tileindex. You
can take a look at gdal utilities that deal with rasters at
http://www.gdal.org/gdal_utilities.html
regards, dejan
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Antonio
> Sent: Thursday, August 09, 2007 12:32 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] use of shp2tile and ogrtindex
> Hi,
> I am using shp2tile to split my huge shapefile , after that I
> use ogrtindex to generate the tileindex.
> So in my map file in the layer definition I set the keyword
> TILEINDEX at this new tilendex shape just generated.
> This work fine for the layer with TYPE POLYGON but doesn't
> work with RASTER layer.
> Some one could tell me why?
> thanks
> Antonio
> PLEASE WARNING: E-mail is CHANGED
> volpicelli at oato.inaf.it
