MS 5.0b3 - AGG compile errors
William Kyngesburye
woklist at KYNGCHAOS.COM
Fri Aug 10 00:23:13 EDT 2007
Ah, I'm not alone on OSX on the messy AGG+FreeType build. I added my
OSX version to that ticket.
On Aug 9, 2007, at 7:41 PM, Stephen Woodbridge wrote:
> I created this Ticket #2215: HowTo Build AGG with freetype support
> from sources, http://trac.osgeo.org/mapserver/ticket/2215
> Have a look it probably will help you for Linux and Jeff added some
> info on Windows. You will need to follow this if you do not install
> AGG as a distro package.
> -Steve W
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed
robot?
[Marvin] You think you have problems? What are you supposed to do
if you ARE a maniacally depressed robot? No, don't try and answer,
I'm 50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
