Java Mapscript error.
Anderson Guiera aguiera at GMAIL.COM
Fri Aug 10 10:00:56 EDT 2007
Hi list!!!!
I would like to say that i solve this problem, which i posted last August,
7th.
Even seted up the environment path as follow
PATH=c:\ms4w\Apache\cgi-bin;c:\ms4w\tools\gdal-ogr;c:\ms4w\tools\mapserv;c:\ms4w
\tools\shapelib;c:\ms4w\proj\bin;c:\ms4w\tools\shp2tile;c:\ms4w\tools\shpdiff;c:
\ms4w\tools\avce00;c:\ms4w\Apache\cgi-bin\mapscript\java;C:\Notes\;C:\Notes\Data
\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program
Files\Starb
ase\StarGate SDK\Lib;C:\Arquivos de
programas\Rational\common;C:\Apl\oracle\ora9
0\bin;C:\Apl\oracle\ora90;C:\Arquivos de programas\Borland\StarTeam SDK
2005\Lib
;C:\Arquivos de programas\Borland\StarTeam SDK 2005\Bin;C:\Arquivos de
programas
\Java\jdk1.5.0_01\bin;C:\Arquivos de programas\VoiceAge\Common;C:\Arquivos
de pr
ogramas\Borland\StarTeam SDK 2006\Lib;C:\Arquivos de
SDK 2006\Bin;O:\SDS;W:\UTIL;O:\SDS;W:\UTIL
the files libpq.dll, mpr.dll and pdflib.dll was referenced in
C:\windows\system32. I've replaced their extension to .old, then Java
mapscript started to work, because the new reference to this files is
c:\ms4w\Apache\cgi-bin.
This is a temporary fix, if you have any sugestion to improve this solution
it'll welcome.
Best regards
Anderson Guiera.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070810/6775d615/attachment.html
