mapserver and arcinfo coverages
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Fri Aug 10 14:01:47 EDT 2007
This page may help:
http://mapserver.gis.umn.edu/docs/reference/vector_data/ArcInfo
Laura Poggio wrote:
> It is some days I am fighting with the possibility to "draw" arcinfo
> coverages with mapserver.
> Below there is the code I finally manage to write for the map file but
> it does not work and I do not know how to solve it. I can "draw" raster
> and shapefiles without problems, but not coverages
> LAYER
> NAME 'built'
> DATA "D:/ALRPC/Gis/Data/Grugliasco/Ext/CTR/Vec/CoverageLP/gru_built"
> TYPE polygon
> STATUS OFF
> CONNECTIONTYPE OGR
> CONNECTION
> "D:/ALRPC/Gis/Data/Grugliasco/Ext/CTR/Vec/CoverageLP/gru_built, 3"
> CLASS
> COLOR 255 0 0
> END
> END
> The command I use to recall the map file in the browser page is:
> http://localhost/cgi-bin/mapserv.exe?map=/ms4w/tmp/mapfile/prova.map&layer=built&mode=map
> <http://localhost/cgi-bin/mapserv.exe?map=/ms4w/tmp/mapfile/prova.map&layer=built&mode=map>
> If someone can help, thank you very much in advance
> Laura
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
