*****SPAM***** Re: [UMN_MAPSERVER-USERS] command line tool to extract georef from gtif
Antonio volpicelli at OATO.INAF.IT
Sat Aug 11 05:30:19 EDT 2007
Spam detection software, running on the system "sam.oato.inaf.it", has
identified this incoming email as possible spam.  The original message
has been attached to this so you can view it (if it isn't spam) or label
similar future email.  If you have any questions, see
the administrator of that system for details.
Content preview:  Thanks nishith, my problem is that I need to generate
  automatically the external referencing files. With gdalinfo/ogrinfo I
  have to write by hand each file. I have about 20K image files. Thank
  Ciao Antonio [...]
Content analysis details:   (5.5 points, 5.0 required)
 pts rule name              description
 2.0 RCVD_IN_SORBS_DUL      RBL: SORBS: sent directly from dynamic IP address
                            [87.4.67.84 listed in dnsbl.sorbs.net]
 1.8 RCVD_IN_DSBL           RBL: Received via a relay in list.dsbl.org
                            [<http://dsbl.org/listing?87.4.67.84>]
 1.7 RCVD_IN_NJABL_DUL      RBL: NJABL: dialup sender did non-local SMTP
                            [87.4.67.84 listed in combined.njabl.org]
An embedded message was scrubbed...
Subject: Re: [UMN_MAPSERVER-USERS] command line tool to extract georef from
 gtif
Date: Sat, 11 Aug 2007 11:30:19 +0200
Url: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070811/4897efd4/attachment.mht
