AGG Rendering with mapserver 5.0
Zhonghai Wang zhonghaiw at GMAIL.COM
Sat Aug 11 10:27:14 EDT 2007
Hi there,
I followed the instructions here:
http://trac.osgeo.org/mapserver/ticket/2215
to build AGG-2.4 with MSVC8, but i get an error message like:
NMAKE : fatal error U1073: don't know how to make 'agg_font_freetype.obj'
seems that the added obj in line 26 causes this error.
I am using the make file downloaded from the aforementioned URL link, which
is added by *jmckenna* on 08/10/07 08:52:06.
Any hints for this error?
Best Regards
Zhonghai
On 8/11/07, thomas bonfort <thomas.bonfort at gmail.com> wrote:
> have you set IMAGETYPE AGG_PNG ?
> On 8/11/07, Steve Smith <ssteve52 at yahoo.com> wrote:
> > The instructions below did not appear to help.
> > I tried installing the 32bit agg libraries into /usr/lib using the
> > fedora package manager, and then re-configed and compiled mapserver. I was
> > able to compile mapserver, but unfortunately the graphics still appear to be
> > GD.
> > Steve
> > *Stephen Woodbridge <woodbri at SWOODBRIDGE.COM >* wrote:
> > Ticket #2215: HowTo Build AGG with freetype support from sources,
> > Steve Smith wrote:
> > > I am attempting to use AGG with mapserver-5.0.0-beta3. I am using the
> > > following OUTPUTFORMAT statement in my .map file:
> > > OUTPUTFORMAT
> > > NAME 'AGG_PNG'
> > > DRIVER AGG/PNG
> > > IMAGEMODE RGB
> > > END
> > > Is this correct? The graphics do not look like AGG. Are there other
> > > statements in the .map file that could result in the use of GD
> > graphics?
> > > I followed the explanations in:
> > > http://mapserver.gis.umn.edu/docs/howto/agg-rendering-specifics
> > > but, still no success. Configuring and compiling mapserver was
> > > successful. No errors occurred. I initially had a problem configuring
> > > with AGG, using libraries in /usr producing the following error
> > message:
> > > checking if AGG support requested... configure: error: "could not find
> > > agg_rendering_buffer.h or libagg.a in /usr."
> > > I think this error was a result of my machine being 64 bit, which the
> > > current beta versions does not recognize. Things worked after I
> > changed
> > > the directory to an AGG installation in /usr/local/agg.
> > > Steve
> > > Shape Yahoo! in your own image. Join our Network Research Panel today!
> > Yahoo! oneSearch: Finally, mobile search that gives answers<http://us.rd.yahoo.com/evt=48252/*http://mobile.yahoo.com/mobileweb/onesearch?refer=1ONXIC>,
> > not web links.
> > Need a vacation? Get great deals to amazing places
> > <http://us.rd.yahoo.com/evt=48256/*http://travel.yahoo.com/;_ylc=X3oDMTFhN2hucjlpBF9TAzk3NDA3NTg5BHBvcwM1BHNlYwNncm91cHMEc2xrA2VtYWlsLW5jbQ-->on
> > Yahoo! Travel.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070811/91b5d910/attachment.html
