MapServer 5.0 Beta3 - msQueryByPoint issue
Howard Butler hobu.inc at GMAIL.COM
Sun Aug 12 19:11:12 EDT 2007
Mike,
Which driver are you using?  IIRC, you had used the ArcSDE driver
some in the past.  If you still are, could you please file a ticket
with some detailed examples?
Howard
On Aug 12, 2007, at 4:26 PM, Mike Saunt wrote:
> Hi All
> Not sure if this should really go to the MapServer Development list
> - although I'm not a member of that list anyway.
> Has anyone else had an issue with nquery / msQueryByPoint /
> msQueryByRect with Beta3 of MapServer 5.0?
> This query against a single layers and we have others that Query
> against multiple in one go.
> http://localhost/mapserver5.0/mapserv.exe?map=D:/Maps/BaNES/
> _MapServerConfig/BaNES.map&mode=nquery&mapsize=987
> +386&img.x=511&img.y=87&imgext=328010.483766+145811.5+403519.516234
> +175295.25&layers=CivicAmenitySites&map_CivicAmenitySites_tolerance=10
> &map_CivicAmenitySites_template=_MapServerTemplates/
> CivicAmenitySites_fields.xml
> All map rendering is working great (love the AGG renderer!) but
> none of our spatial query (NQUERY etc) strings are working.  I
> can't see anything from the Migration Guide as to what could be
> wrong...
> Any help appreciated or a pointer to the MapServer dev list...
> Cheers
> Mike
