minfeaturesize auto
Gregor Mosheh
gregor at HOSTGIS.COM
Mon Aug 13 14:17:52 EDT 2007
Hey, guys, I hate to be a pest about this, but my employer would like
for me to confirm whether this is a known bug (I can't find it in Trac),
user error on my part (not impossible, though "minfeaturesize auto"
seems straightforward), or an unknown bug, so we can plan appropriately.
Issue:
"minfeaturesize auto" is documented as causing labels to appear only
when their containing polygon is larger than the label. In my tests, it
causes labels to never be displayed.
Demonstrations:
Default label handling:
http://maps.hostgis.com/gregor/mww_example/
http://maps.hostgis.com/gregor/mww_example/mapfile.txt
LABEL
COLOR 0 0 0
TYPE truetype
FONT "Arial"
SIZE 9
POSITION cc
END
Minfeaturesize 36:
http://maps.hostgis.com/gregor/mww_example3/
http://maps.hostgis.com/gregor/mww_example3/mapfile.txt
LABEL
COLOR 0 0 0
TYPE truetype
FONT "Arial"
SIZE 9
POSITION cc
MINFEATURESIZE 36
END
In this case, there are still several polygons (note the northeast quad
of the map) which lack labels though they're above the minimum size and
labels would not collide. That's probably beyond the scope of this
submission, but is still interesting and my employer considers it "bug like"
Minfeaturesize auto:
http://maps.hostgis.com/gregor/mww_example2/
http://maps.hostgis.com/gregor/mww_example2/mapfile.txt
LABEL
COLOR 0 0 0
TYPE truetype
FONT "Arial"
SIZE 9
POSITION cc
MINFEATURESIZE auto
END
Note that labels are never displayed. This is also the case even if
"FORCE true" is set.
I'm glad to file a bug report on this, and even to dive into the source
code and see what I can do. (My C is weak but willing.) I just need to
know whether others can replicate this, to rule out the possibility of
user error.
Gregor Mosheh / Greg Allensworth
System Administrator, HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
only if you can restore." - AMANDA
