Speeding up load time for huge SHP files
Jan Hartmann j.l.h.hartmann at UVA.NL
Mon Aug 20 07:33:06 EDT 2007
Ed McNierney wrote:
>   If that's your
> problem, you need a different, simplified version of that shapefile
> (using MINSCALE/MAXSCALE to select the right one) for use at small
> scales.
Hi Ed,
How would you produce that simplified version is none is available already?
Jan
