how get itemnquery result for manage output with AJAX to client ?
Richard Greenwood richard.greenwood at GMAIL.COM
Mon Aug 20 16:24:12 EDT 2007
On 8/20/07, Rodrigo Haas <rodrigohaas at gmail.com> wrote:
> Richard,
> Thanks for response!
> I have a template query, "template_query.html"
> (<tr><td>[attribute1]</td><td>[attribute2]</td> ....)
> and it is setup in mapfile:
>  LAYER
> CLASS
> TEMPLATE "template_query.html"
> END
> END
> I can see query result in new page, it's work fine. But the content of the
> file "xxx.qy" saved in tmp to folder is equal: "? W1A'X? aA…." !
> This is correct?
> The content of the file "xxx.qy" it would have to be "[value1] [value2]..."
That is a binary file that is usually used with a map. For example, if
you highlight an object on the map, and want to keep it highlighted as
the user zooms and pans, you would use the xxx.qy to keep the object
highlighted.
But in your case, you just want the attributes, right? Or do you want
the map object(s) also?
Rich
Richard Greenwood
richard.greenwood at gmail.com
www.greenwoodmap.com
