PHP wrapper for mapserv CGI
Gregor Mosheh
gregor at HOSTGIS.COM
Mon Aug 20 16:50:47 EDT 2007
> I'd like to do the same thing, but with PHP. The best I've go so far is:
> <?php
> passthru("/www/cgi-bin/mapserv QUERY_STRING=map=/path/to/mapfile.map");
> Which uses the QUERY_STRING option to execute mapserv in a "shell
> mode". It works, but I wonder if there is a better way, and/or if this
> is a bad way to do it.
Oh, that is just slicker than anything. As long as you're not allowing
the user to supply unchecked data (e.g. the path to the mapfile
containing shel metacharacters), that's just excellent.
Gregor Mosheh / Greg Allensworth
System Administrator, HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
only if you can restore." - AMANDA
