PHP/Mapscript error - help needed
Dejan Gambin dejan.gambin at PULA.HR
Tue Aug 21 16:09:12 EDT 2007
Thank Frank, Attila
I really had another libgdal binary version installed. I removed it using
apt-get remove and now everything is fine.
Thanks again,
regards, dejan
> -----Original Message-----
> From: Attila Csipa [mailto:plists at prometheus.org.yu]
> Sent: Tuesday, August 21, 2007 3:56 PM
> To: Gambin Dejan
> Subject: Re: [UMN_MAPSERVER-USERS] PHP/Mapscript error - help needed
> On Tuesday 21 August 2007 15:46, Gambin Dejan wrote:
> > Since I couldn't find gdal-config on my server and I needed it for
> > configure script, I have downloaded/compiled/installed
> 1.4.2 version
> > of gdal. After that I was able to install php/mapscript.
> > gdal-config --version says: 1.4.2
> > gdal-config --libs says: -L/usr/local/lib -lgdal gdal-config
> > --ogr-enabled says: yes gdal-config --dep-libs says: -lodbc
> -lodbcinst
> > -ljpeg -ltiff -lpng -lz -lm -lrt -ldl -L/usr/lib -lcurl -L/usr/lib
> > -lgssapi_krb5 -lkrb5 -lk5crypto -lkrb5support -lcom_err
> -lresolv -lidn
> > -lssl -lcrypto -ldl -lssl -lcrypto -lz
> > What are you suggesting me to do?
> You might already have a binary version of libgdal in
> /usr/lib that came with your distribution which is
> interfering (you're compiling with the version in
> /usr/local/lib, but using it with the one in /usr/lib). Try
> ldd /usr/lib/php5/20051025/php_mapscript_410
> it should write out what .so-s it is calling - if it lists
> /usr/lib/libgdal...
> you know that's the problem. In that case either remove the
> binary gdal package (which can get tricky since it can cause
> dependancy problems) or move the /usr/local/lib path before
> /usr/lib in /etc/ld.so.conf and run /sbin/ldconfig -v, but
> that has potentially even more drawbacks as it may break other .so-s.
