AGG: missing truetype label outlinecolor on Windows/VC8
thomas bonfort thomas.bonfort at GMAIL.COM
Wed Aug 22 12:26:12 EDT 2007
andreas,
the outlining code for fonts is merely about drawing the same text offset by
one pixel in each direction (N, NE, E, etc ). I've changed a few things
today in the font rendering code, could you possibly check with the svn
version (or with beta5 due today I think) that this bug is still present
when optimisation is on.
tb
On 8/20/07, Andreas Albarello <andreas.albarello at territoriumonline.com>
wrote:
> Folks,
> some strange things are happening here with MapServer 5.0 beta 4 (as
> well as all the previous betas) regarding AGG truetype label rendering.
> For instance, when compiling MapServer with VC8, more precisely Visual
> C++ 2005 Express SP1, against agg 2.4 (compiled with the makefile
> provided by Jeff McKenna) and libfreetype 2.2.1, both compiled with VC8
> as well, my truetype labels suddenly have no outlinecolor anymore. When
> I change the outputformat back to use GD for rendering, everything is
> fine. I can reproduce this behavior on two different machines, even
> through shp2img with a basic mapfile having just an annotation layer.
> Funny thing is, and I came up with this more by chance than anything,
> when I disable compiler optimizations by tweaking Makefile.vc to pass
> /Od instead of /Ox to the compiler for mapagg.cpp only (all other files
> and libraries, including agg, are compiled with optimizations on) I'm
> able to get my outlinecolors working again. This smells a lot like a
> compiler bug to me. If some Windows folks out there can perhaps confirm
> this, I'm ready to file a bug report on this, in order to at least tweak
> the Windows makefile (well, I guess that's most likely the only thing we
> can do about this).
> Best regards,
> Andreas Albarello
> Analysis & SW Development
> Territorium Online srl/GmbH
> Via Buozzi Str. 12
> I 39100 Bolzano/Bozen
> Phone:  +39 0471 068611
> Fax:    +39 0471 068619
> email: andreas.albarello at territoriumonline.com
> web:   http://www.territoriumonline.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070822/733bbd82/attachment.html
