AGG and WMS
Christopher Schmidt crschmidt at METACARTA.COM
Thu Aug 23 15:03:56 EDT 2007
On Thu, Aug 23, 2007 at 12:32:41PM -0600, Brent Fraser wrote:
> Is AGG supposed to do anti-aliased output when Mapserver is
> used as a WMS server?
I'm not sure what 'antialiased' output means -- perhaps you mean 'alpha
transparency', perhaps you mean antialiasing within the images, perhaps
you mean something else. Can you clarify?
The answer to the first is, I believe,  "no". WMS spec only allows for
'transparency or no transparency', and MapServer does not implement
alpha transparency output in the WMS images.
The answer to the second is "Sure" -- the images for
http://boston.freemap.in/ are fetched from WMS (by TileCache).
Regards,
Christopher Schmidt
MetaCarta
