first-time install, error on make
Gregor Mosheh
gregor at HOSTGIS.COM
Sat Aug 25 19:01:14 EDT 2007
> /usr/bin/ld: warning: libXpm.so.4, needed by
> /home/alttwois/lib/gd-2.0.35/.libs/libgd.so, not found (try using -rpath
> or -rpath-link)
> /usr/bin/ld: warning: libX11.so.6, needed by
> or -rpath-link)
> /home/alttwois/lib/gd-2.0.35/.libs/libgd.so: undefined reference to
> `XpmReadFileToXpmImage'
> collect2: ld returned 1 exit status
> make: *** [shp2img] Error 1
There ya go -- your GD was compiled with Xpm support, but the Xpm
library isn't found. Try this:
ldconfig -p | grep -i xpm
That'll show whether Xpm is installed.
Alternative:
If you compiled GD yourself, and my memory serves, you can give
--without-x to have it skip X-Window stuff. You won't miss it. :)
Gregor Mosheh / Greg Allensworth
System Administrator, HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
only if you can restore." - AMANDA
