first time mapserver install, error on empty query
Tara Athan tara_athan at ALT2IS.COM
Sun Aug 26 15:36:10 EDT 2007
Thanks for your patience...
I found libgdal.so.1 in /home/alttwois/local/lib
I created the script named mapserv as follows
  #!/bin/sh
  export LD_LIBRARY_PATH="/home/alttwois/local/lib"
  exec /home/alttwois/public_html/cgi-bin/mapserv.real
On running ./mapserver -v, I get the same error message as before
/home/alttwois/public_html/cgi-bin/mapserv.real: error while loading
shared libraries: libgdal.so.1: cannot open shared object file: No such
file or directory
Tara
Gregor Mosheh wrote:
> Tara Athan wrote:
>> I have limited access to the webserver.
> Good to know.
>> Don't Options 2 and 3 depend on there being a file libgdal.so.1
>> somewhere?  I cannot find any such file.
> If you sucessfuly did a make and make install as you describe, there
> should be a directory /home/alttwois/local/lib and inside it should be
> among other things libgdal.so
> If not, then backtrack and tell us how your GDAL/OGR build went.
> If so, then /home/alttwois/local/lib is the library path. Create a
> shell script and stick it into cgi-bin:
>   #!/bin/sh
>   exec /path/to/cgi-bin/mapserv
> That wrapper should do the trick, for both command line and CGI.
My e-mail delivery has been unreliable lately, so I am asking for
return receipts from all my email messages.
OK'ing the return receipt lets me know that my message was delivered.
Thank you.
Tara Athan
Principal, Alternatives to Invasive Species
tara_athan at alt2is.com
707-485-1198
PO Box 415
Redwood Valley, CA 95470
