Article about MapServer 5.0
Daniel Morissette
dmorissette at MAPGEARS.COM
Tue Aug 28 05:58:07 EDT 2007
Thomas,
When I first used AGG it was not obvious how to setup the outputformat.
It would probably be a good idea to add those outputformat infos to your
http://mapserver.gis.umn.edu/docs/howto/agg-rendering-specifics page.
Daniel
thomas bonfort wrote:
> Another question, I tested the new outputformat with AGG, is it
> possible
> to get jpg or gif image with it? If so, how can I setting up my mapfile
> to realize this? Do I need special flag when building mapserver?
> gif isn't supported with agg.
> these are the main outputformats you can use with agg:
> base outputformat, will output a 24 bit png:
> OUTPUTFORMAT
> NAME 'AGG'
> DRIVER AGG/PNG
> IMAGEMODE RGB
> END
> 24 bit png, rendered on a transparent background:
> OUTPUTFORMAT
> NAME 'AGGA'
> DRIVER AGG/PNG
> IMAGEMODE RGBA
> END
> 24 bit jpeg output:
> OUTPUTFORMAT
> NAME 'AGG_JPEG'
> DRIVER AGG/JPEG IMAGEMODE RGB
> END
> png output, with number of colors reduced with quantization:
> OUTPUTFORMAT
> NAME 'AGG_Q'
> DRIVER AGG/PNG
> IMAGEMODE RGB
> FORMATOPTION "QUANTIZE_FORCE=ON"
> FORMATOPTION "QUANTIZE_DITHER=OFF"
> FORMATOPTION "QUANTIZE_COLORS=256"
> END
> as for building, it will depend on your platform, but generally speaking
> you'll run
> ./configure [...] --with-agg=/usr [...] if you're using a distro build
> of agg
> or
> ./configure [...] --with-agg=/path/to/agg-source [...] if you're using a
> downloaded version from antigrain.com <http://antigrain.com> (you'll
> have to build agg in the source directory before doing this. just
> running 'make' should be enough)
> happy to answer other questions if any (en francais aussi, si c'est plus
> facile)
> thomas
Daniel Morissette
http://www.mapgears.com/
